B18c5 into EK throttle cable problem
Old Nov 18, 2013 | 06:01 PM
BC_Garage's Avatar
Default B18c5 into EK throttle cable problem
I have a GSR with Skunk2 intake manifold in my EK. I am using an ITR throttle cable and ITR throttle cable bracket and the cable is really loose. What am I doing wrong. I want to use the ITR bracket. It is a show car and I prefer not to use the flat black bracket.
Old Nov 18, 2013 | 06:03 PM
efiniracer92's Avatar
Default Re: B18c5 into EK throttle cable problem
have you tried adjusting the bracket forward on the throttle cable?
Old Nov 18, 2013 | 06:09 PM
B_Swapped93's Avatar
An EK....no it's a EJ6.
you adjust the slack via the t bolts that hold it on the bracket I circled them here.
Old Nov 18, 2013 | 06:12 PM
TripleLude's Avatar
Well, if you can install an intake manifold properly and also do an engine swap, I would assume you already know how to adjust a throttle cable, right?
So what is the problem, or what happens when you try to adjust it? Is it at the end of adjustment?
If it's only a show car, it doesn't need proper adjustment. In fact, the car doesn't even need to run properly, so just put the one on there that looks best.
TripleLude's Avatar
**Double post please delete**
Old Nov 18, 2013 | 07:56 PM
BC_Garage's Avatar
It's at the end of the thread. It cannot be adjusted anymore. I've already gone through that. its just super loose. If i move the ITR bracket to the right holes so only one hole in the bracket is attached to the manifold then it will have the proper tension but I don't want to do that. I thought that people run ITR brackets and cables in EKs. That's why it doesnt make sense to me.
Old Nov 18, 2013 | 08:02 PM
was the throttle cable new when you bought it ? I have tons of room to adjust mine tighter or looser
Old Nov 18, 2013 | 08:04 PM
BC_Garage's Avatar
The ITR cable and bracket were both brand new from Acura. The adjusting nut is at the very end and there is still a lot of slack in the cable after the bracket.
Old Nov 18, 2013 | 08:15 PM
what throttle body ? something doesn't add up if they're both new from acura,
Old Nov 18, 2013 | 08:17 PM
BC_Garage's Avatar
b16 throttle body.
Old Nov 18, 2013 | 08:21 PM
how old is the cable I've seen them stretch. for the price of 30$ I suggest picking up a new one.
Old Nov 18, 2013 | 08:26 PM
BC_Garage's Avatar
The cable is brand new.
Old Nov 18, 2013 | 08:28 PM
ok last suggestion HOW is it ran from the firewall to the bracket.....need a pic 100%
Old Nov 18, 2013 | 08:41 PM
BC_Garage's Avatar
Would that affect it though? It has slack after the bracket. Basically between the throttle body pulley and bracket on the intake manifold. This is how it is ran.
Old Nov 18, 2013 | 08:48 PM
Marvin1985's Avatar
You will have some slack on it bro. Just x2 check that at wot (pedal to floor) that the TB is fully opened like it should. My b swap had the same bracket. I just adjusted it all the way and it's good
Old Nov 18, 2013 | 08:49 PM
try looping it over/around the brake master cyl it may fix things I'd go try mine like you have your but my engines out of the car.
edit:there will be some slack but it looks like OP has too much, mine is set in the middle and I have just a bit of slack.
Old Nov 18, 2013 | 08:51 PM
Marvin1985's Avatar
Dude relax on the dick comments. Check Bc build. They way beyond 90% off honda people. He has a legit issue not a scrub lazy commoner Ht user problem
Old Nov 18, 2013 | 08:52 PM
Marvin1985's Avatar
BC why no use a B16 cable from honda?
Old Nov 18, 2013 | 08:54 PM
lol it's "THEY'RE" wise guy.....and 2nd how is suggesting buying a new cable based on the fact I've seen them stretch a dick comment.
edit: hey genius look at how the b16 and ITR manifold/TB sit....same deal
Old Nov 18, 2013 | 08:58 PM
BC_Garage's Avatar
I'm thinking about trying an em1 cable if I can't get this figured out. Its just mine seems to have a bit too much slack.
BC_Garage's Avatar
I'll try looping it that way and see if it changes anything.
Old Nov 18, 2013 | 09:04 PM
Marvin1985's Avatar
It's either the cable or bracket itself. B swapped, the other end of the cable could be different because of the em1 vs dc pedal assembly. Also he states it was new before hand and you were like "is it stretched?" Blah blah.
Old Nov 18, 2013 | 09:07 PM
Marvin1985's Avatar
lol see
Old Nov 18, 2013 | 09:08 PM
just stop there and lets try to help. you can't say anything after that comment
yes i'm doubting him if that is the issue I've never seen that come up with a new cable now learning OP has routed it differently I still keep that suggestion on the board
Old Nov 18, 2013 | 09:19 PM
BC_Garage's Avatar
Just tried routing it the other way same issue. Still a lot of slack. It almost touches the intake manifold. When I press the throttle to the floor the throttle plate is opened all the way. But I know its still not right.
