91 Accord alternator belt tensioner
Old Nov 18, 2013 | 03:50 PM
zsiya's Avatar
Default 91 Accord alternator belt tensioner
Previous owner took the alternator belt tensioner out. I "acquired" the bolt, but now I've found there is nothing to thread the bolt in to. Is there another part I'm missing from the alternator?
Old Nov 18, 2013 | 11:13 PM
holmesnmanny's Avatar
Default Re: 91 Accord alternator belt tensioner
There are two 10mm bolts in the front plate. One bolts to the alternator the other("special") goes down towards the engine...towards the other end of that bolt there's a bolt that runs 90 degrees through it from the left through that bolt, through the alternator and is held by a one inch long nut on the right side. You tighten the second bolt that I alluded to(labeled "special") to tighten the belt. It will draw the alternator tighter and tighter towards you, which tightens the belt.
Old Nov 19, 2013 | 02:23 AM
zsiya's Avatar
Thanks! Looks like I'll be heading back to the yard.
CHANCELLOR12
Oct 2, 2015 01:55 AM
dviladvct1
Nov 20, 2012 10:31 PM
peter_x
Aug 23, 2009 08:01 AM
nemesiskrp
Apr 14, 2009 10:10 PM
lude1888
Jun 6, 2007 09:26 PM
