GSR Hub/Spindle setup fit on EF's?
Old Oct 27, 2002 | 04:37 PM
AbaZ's Avatar
Default GSR Hub/Spindle setup fit on EF's?
Just curious.. I should know this, but I figured some of you have already done this... I have access to a complete Front Spindle/Hub/Rotor/Caliper assembly from a 94 GSR. Question is, is this a bolt on Deal? The axles should have no problem. All the mounts appear to be in the same spot. The tie Rod may need to be adjusted.. But other than that.. could it be any easier? or am I missing something here. Just looking for a cheap Upgrade on Brakes..
Jeff Frank
sTEGasaurus
Dec 29, 2009 07:41 AM
bradpee
Mar 25, 2009 10:58 AM
aznjay510
Jul 24, 2007 05:01 PM
d15b7racer
Aug 27, 2004 06:58 PM
