Want to Buy Want to Trade/Want to Buy
WTB: MISC GSR PARTS
Old Nov 18, 2013 | 11:35 AM
92bseries's Avatar
Default WTB: MISC GSR PARTS
piecing my motor together and i broke down and thought id make a post here to see if anyone has anything i may need. id prefer the parts be new or SLIGHTLY used. NOTE: ALL PARTS I NEED ARE B SERIES VTEC
i need:
stock bore piston rings
acl bearing kit
arp rod bolts
water/oil pumps
crank pulley
arp head studs
hydro clutch-prefer a stage 1 clutch as i dont want a stock one and dont need a clutch for boost yet
injectors
ctr cams
ill update if i need anything else and ill delete items as i acquire them. lmk people lol
Old Nov 18, 2013 | 12:17 PM
sanjiyan69's Avatar
Default Re: WTB: MISC GSR PARTS
Originally Posted by 92bseries
arp head studs
I have a set. used on my b20/GSR.
tb
Are you looking for a aftermarket TB? I have a professional product 68mm TB that will work if you have an aftermarket IM (I have it on the Edelbrock PerformaX IM for GSR head)
fuel rail
Again, aftermarket? I have an used Professional Products B series fuel rail.
Old Nov 18, 2013 | 12:29 PM
92bseries's Avatar
my bad should have specified so my apologies. yes i would like aftermarket stuff
Old Nov 18, 2013 | 12:30 PM
92bseries's Avatar
does the tb come with the tps??
Old Nov 18, 2013 | 12:57 PM
CHEETAH's Avatar
i need:
acl bearing kit
arp rod bolts
water/oil pumps
crank pulley
arp head studs
tb
fuel rail
injectors
gsr/ctr cams
stock bore piston rings - need high compression or low compression?
water/oil pumps - brand new or low mileage used ok?
I have the following:
crank pulley (bolt if needed too)
6 puck clutch disc, ACT pressure plate, and ACT lightened flywheel.
310cc injectors, if you need bigger for turbo i have some 95 lb injectors (peak/hold) so i also have a resistor box
gsr cams and adj cam gears
used 81mm pistons with rings in great condition
pm me if interested in any of the stuff above.
Old Nov 18, 2013 | 05:53 PM
sanjiyan69's Avatar
comes with MAP and TPS. I can text you pics.
Old Nov 18, 2013 | 09:42 PM
guy_from_nerk's Avatar
I have a couple different used water pumps, oil pumps, rear main seal housings with seal, factory oil cooler with water next and oil pan. Pm if interested in anything
Old Nov 18, 2013 | 09:57 PM
NUISANCE's Avatar
I have the head studs and clutch in my FS thread. Keep in mind everything listed is OBO so throw me some reasonable offers and I am sure we can make it work.
http://hondamarketplace.com/showthread.php?t=3180081
Old Nov 19, 2013 | 03:41 AM
JerseySiPOS's Avatar
Parts, images and prices of some of your wtb parts here:
http://hondamarketplace.com/showthread.php?t=3175127
http://hondamarketplace.com/showthread.php?t=2978807
Fast shipping with tracking number. Private message me if interested.
Old Nov 19, 2013 | 07:35 AM
92CivicSiOEM's Avatar
I have injectors and BNIB King bearings...PM if interested!
Old Nov 19, 2013 | 08:57 AM
Royal_C!ty's Avatar
pm'd
Old Nov 20, 2013 | 05:06 PM
92bseries's Avatar
cheetah, have pics of the clutch and gsr cams? might need that crank pully
sanjiyan, you able get me some pics of the tb please?
all other pms replied. ttt
Old Nov 20, 2013 | 05:41 PM
sanjiyan69's Avatar
text me. 6165402839. I got pics on my phone.
Old Nov 21, 2013 | 08:07 AM
S2Integra's Avatar
I have gsr cams and cam gears, exedy stage 1 clutch and exedy chromoly flywheel, arp head bolts, crank pully and water pump, and fuel rail
Old Nov 21, 2013 | 02:08 PM
Charlie Moua's Avatar
gsr cams $30
gsr rods & pistons in good condition & very clean $30
Old Nov 22, 2013 | 10:52 AM
ALLMOTOR18's Avatar
I have:
brand new ACL Mains
JG Edelbrock 65mm TB (part number for ITR)
low mileage OEM water pump
Old Nov 22, 2013 | 04:25 PM
Royal_C!ty's Avatar
pm'd
Old Nov 23, 2013 | 02:24 PM
Decatur Racer's Avatar
pmd
Old Nov 25, 2013 | 04:15 PM
forcfedcivic's Avatar
I have a south bend clutch available.....with flywheel....just seated in when I took out the engine....maybe 1000k on it
Old Nov 28, 2013 | 08:39 PM
SFWD 1934's Avatar
i need:
acl bearing kit
arp rod bolts
water/oil pumps
crank pulley
arp head studs
tb
fuel rail
injectors
gsr/ctr cams
I have a brand new silver AEM fuel rail or a stock fuel rail
I have stock injectors that were just cleaned and balanced
I have stock GSR cams or JG turbo cams
Let me know.
Jason
Old Nov 30, 2013 | 09:17 PM
SlaminSohCivic's Avatar
ive got a mint ITR Throttle body no map or TPS $35.00 SHIPPED
Old Dec 7, 2013 | 11:40 PM
seanc520's Avatar
ive got a crank pulley 35 shipped
Old Dec 11, 2013 | 04:32 PM
Slimmy101's Avatar
I got skunk2 pro3 cams brand new in box $650
Old Dec 31, 2013 | 02:09 PM
jayzx6r's Avatar
PM'd
Old Jan 16, 2014 | 10:20 PM
efkilla's Avatar
I got the arb rod bolts
35 shipped
