Auto to Manual Swap in progress. Clutch pedal switches bypass or DIY?
So here's the issue. I'm currently in the process of swapping my r18 from auto to manual and I've just installed the CMC and clutch pedal. The problem is, since my wiring is for an auto my under dash does not have the connections for the clutch interlock and clutch pedal position switches. I've done some research and it appears that the car has a spot for the connections behind the fuse block I just have to have the male and female end connector harness. Does anyone know where I can buy them or make them somehow? Because thats the only thing holding me back from being 100%. Everything else is an easy swap.
have you tried checking at the parts department at Honda?
if not you can always go check here at www.majestichonda.com
I for one couldn't really tell you if they do but hopefully you will be able to find them.
See I had thought about the dealership but I didnt want to pay ten times as much for the connector lol. So I asked hoping someone knew a cheaper alternative. But I will check out that website, hopefully they have something.
Appreciate the help!
Well I've been swooping through website after website and so far I cannot find the actual connector. I can find the switch but not what it plugs in to. Looks like I may need to make one or hopefully find a junk yard or something. Unless someone has another idea? I welcome suggestions.
Well. I called a dealer to get more information on the connectors. Turns out the connections are part of a "engine room wiring harness" it feeds through the firewall and plugs in to the headlight, horn, airbags, and things of that nature on the drivers side of the car. He said they cant sell just the connections only the entire harness which costs $687! So if someone has an idea on how to "jump" the connection or wire things together, I am certainly all ears.
