4x100 to 4x114.3 conversion
somebody wants to trade me some 4x114.3 gab sports for my regamasters plus some cash so i was wondering what is involved in a 4x114.3 swap, just swap the spindles/trailing arms/control arms over and bleed the brakes, or do i need different axles in the front too? thanks
ive also already found a 4x114.3 conversion setup, just need to know if my 32mm axles will work in it or not
Only thing that will be different is the lug holes in the rotor/hub.
I swapped back from 4x114 and left the calipers on so I didn't have to bleed the brakes.
The earlier 4lug accord is also the same lug pattern if you're looking for spares.
Axles are the same, and you can use the same calipers.
jaerikd
Oct 1, 2009 11:07 PM
