Timing belt
Old Nov 16, 2013 | 03:59 PM
foxyride22's Avatar
Default Timing belt
Hello, I got a 92 ex automatic. Trying to buy a new timing belt and I don't wanna buy anything of poor quality. Any suggestions of good brands?
Old Nov 17, 2013 | 06:27 PM
78F350's Avatar
Default Re: Timing belt
I was just looking at doing that on another car. I'd recommend getting a Gates belt with a kit (Belt & water pump) from Amazon.com
Old Nov 18, 2013 | 02:07 PM
foxyride22's Avatar
thats what i ended up getting, now the only problem in encountering is the balance shaft. how do you know if you got it locked and can a alan wrench be used to hold that balance shaft?
Old Nov 18, 2013 | 04:25 PM
brakedrum's Avatar
A good quality screwdriver is best. A big bright handle also reduces the chance of forgetting it's in there.
Old Nov 19, 2013 | 12:04 AM
holmesnmanny's Avatar
With the engine in the car there's isn't a lot of room to fit a screwdriver in there that is the correct radius size. A 15/64 drill bit works best. Just mark it 3 inches from the end stick it in and it should bottom out around 3 inches. Gates makes honda belts so go Gates.
Old Nov 19, 2013 | 03:28 PM
mtnickel's Avatar
As a tip that I don't always see mentioned, it can be quite beneficial to put dots of paint on the belt teeth as well as all the different gears (markers basically). Then you can copy the marks onto your new belt. Gives a really good sanity check to make sure things go back exactly how they are supposed to. With the flex of the cam gear and all the tensioner stuff it's easy to skip a tooth on something if you're not extra careful (especially when the engine is in the car and you don't have the best lines of sight to things). Good luck!
Mark
Old Nov 19, 2013 | 10:11 PM
ya I use whiteout to make marks across everything just to be sure
Sheela96
Dec 17, 2014 05:23 AM
honda2112
Apr 15, 2010 05:10 AM
rasta420
Dec 21, 2008 09:52 PM
honda94accord
Apr 10, 2007 05:39 AM
JiggaFan
Feb 21, 2003 09:52 AM
