car gets no spark when air temp is below 40.
Old Oct 27, 2002 | 03:59 PM
kamikazee's Avatar
Default car gets no spark when air temp is below 40.
HELP ME PLEASE. My '91 Accord EX gets no spark when the outside temp is less than 40. When the temp is above 40, it starts as soon as I turn the key. It has all MSD ignition components. MSDtech says nothing of theirs is temp sensitive. Honda mechanic does not know what the problem is! He has no experience with aftermarket mods.
Old Oct 27, 2002 | 04:22 PM
Desslok's Avatar
Default Re: car gets no spark when air temp is below 40. (kamikazee)
I remember on my car having a problem with the stock distributor and igniter. Assuming you have the stock distributor, then you probably have the stock igniter module inside, which I think I remember there was a problem with. If you have a manual, I would check each component individually. You usually need to check resistance and voltage, so a multimeter is all you should need.
Brando76
Jan 1, 2013 02:06 PM
sks3266
Oct 29, 2006 12:00 PM
A.E Motoring
Aug 16, 2006 07:04 PM
hondahottie91
Sep 19, 2004 05:02 PM
Chad Bicklmeier
Nov 17, 2002 08:20 PM
