OT: S2000 HID
Old Oct 27, 2002 | 03:55 PM
TypeR1558's Avatar
New User
Default OT: S2000 HID
I saw some sweet HID's coming towards me the other night on the opposite side of the road. I saw them flickering with so much blue and purple... just awesome. Turned out to be an S2000, and I was wondering, do you think it was an aftermarket kit? Or do the stock S2000 housings make the lights colored (like beamers, etc.)?
I'm really interested in running some OEM HID on my R, but i am wondering about cost. Some have said the best way to go is to just get a phillips 4300 kit, and then get ahold of the OEM projectors (like from a BMW). How much would something like X5 projectors cost?
Thanks,
Jon
Old Oct 27, 2002 | 04:41 PM
zer0zer0 TypeR's Avatar
Default Re: OT: S2000 HID (TypeR1558)
that is factory HID on S2000. my friends s2000 NEVER stays the same color. at even the slightest angle the color changes from a rich violet, to blue to pure white. IMO S2000 has the most gorgeous HID's out there.
Old Oct 27, 2002 | 04:48 PM
itr1244's Avatar
Default Re: OT: S2000 HID (zer0zer0 TypeR)
Alost the one of the most gorgeous HID is audi's
looks alot like S2k too
-RedneckDave-'s Avatar
Working
what size bulb do they run?
Old Oct 27, 2002 | 04:53 PM
B2FiNiTY's Avatar
Default Re: OT: S2000 HID (01accordv6)
9006 D2S.
Old Oct 27, 2002 | 04:56 PM
Working
Default Re: OT: S2000 HID (B2FiNiTY)
are those bulbs different from regular 9006 or could i use the ballasts and the bulbs from an S2000 in my accord?
Old Oct 27, 2002 | 04:57 PM
B2FiNiTY's Avatar
Yes you can. But you would want D2R since accords do not come with projector headlights.
If you put the s2k kit on the accord it will NOT come out the same.
Old Oct 27, 2002 | 05:01 PM
Working
i just want really reliable lights that are really bright and i figured that a kit from an S2000 could do that. Or should i just get in on the group buy for a Phillips Kit? what do you think?
Old Oct 27, 2002 | 05:02 PM
B2FiNiTY's Avatar
Get on the group buy for the philips.
Old Oct 27, 2002 | 05:04 PM
Working
Cool man. Thanks.
Old Oct 27, 2002 | 06:05 PM
M0NEYnH0s's Avatar
im a fan of the s2000 lights..maybe this is a dumb question but i really have no clue..
what about using the s2000 hid ballasts on integra projectors?? is it possible?
Old Oct 27, 2002 | 06:08 PM
uNF$@#!'s Avatar
Default Re: OT: S2000 HID (m0neynh0s)
if you want that kind of look, put a thin layer of ion film on your headlights.
Old Oct 27, 2002 | 06:09 PM
Working
Default Re: OT: S2000 HID (Soup ****)
i already have ion lenses.
Old Oct 27, 2002 | 06:37 PM
B2FiNiTY's Avatar
100% possible.
Old Oct 27, 2002 | 06:40 PM
mugenintegra16's Avatar
what about if i have the oem type r hid kit and just use s2000 bulbs will that work will i get the same effect?
Old Oct 27, 2002 | 06:41 PM
B2FiNiTY's Avatar
Default Re: OT: S2000 HID (mugenintegra16)
No. The thing that gives the S2k the effect it does is the bulb housing. Nothing to do with the HID setup.
Old Oct 27, 2002 | 07:59 PM
TypeR1558's Avatar
New User
Anyway to get the HID bulb housing in a JDM front converted integ? I want the S2000 HID look when looking at the car from the outside, and then I would use a Phillips 4300 setup. How do you all recommend doing this, and what would the cost be. I know one guy did it with a part from the X5 in his integ, and got the X5 look. Which parts do I need to look like the S2k, and where can i get them?
Jon
Old Oct 27, 2002 | 08:09 PM
uNF$@#!'s Avatar
the projector.
Old Oct 27, 2002 | 08:57 PM
Tony the Tiger's Avatar
Jon
How did the Integra guy manage to do that? I opened up my headlights and I see no way of making it possible while maintaining stock adjustability. If you are talking about Wayne aka CanuckMX6, he is still in the process of making this conversion possible. I already have X5 projectors retrofitted inside my 1.6EL, so I know what I am working with here
Anyway, swapping to S2000 bulbs, ballast, projector lens, whatever will not get you the same appearance. You will need to swap the entire projector housing from a S2000/Audi/BMW X5 to get the OEM colour-flipping appearance.
Old Oct 27, 2002 | 10:02 PM
STC's Avatar
STC
Default Re: OT: S2000 HID (Tony the Tiger)
if u want the blueish look get the 5000k kit.
Old Oct 28, 2002 | 12:04 AM
Default Re: OT: S2000 HID (STC)
IMO.
Last thing you want is to have a bluish tint to your HID's...
Old Oct 28, 2002 | 12:20 AM
TypeR1558's Avatar
New User
the projector.
So I just need a Phillips 4300k kit, and the S2000 projectors? Where could I get the projectors? Will the S2000 projectors be compatible with the JDM (non-HID front) and a phillips kit?
Jon
Old Oct 28, 2002 | 12:21 AM
B2FiNiTY's Avatar
You will have to custom fabricate it. If you have never done anything like this, I don't suggest it.
You will need:
S2k headlights -> jack the projectors -> install onto JDM headlights
TypeR1558's Avatar
New User
Are the S2000 projectors also what cause them to flicker so much, they seemed to flicker more then other HID's i have seen around as well.
Old Oct 28, 2002 | 12:27 AM
TypeR1558's Avatar
New User
You will need:
Why would i need the S2000 headlights? Cant I use the Phillips ones that come with the 4300k kit? Isn't there somewhere I could just get the projectors?
I will not be doing this work myself, i will explain to my shop what i want done, and they will do it, if it is possible. Seems like we are only dealing with using one part (the projectors), i dont see why they wouldn't be able to find a way to get that in with the phillips kit. I dont feel comfortable trying to put something like this together on my own.
jon
