B16a2 Head..Can I fix this?
Old Nov 15, 2013 | 02:22 PM
HatchSi's Avatar
Default B16a2 Head..Can I fix this?
Just received my 92' PR3-1 head in the mail for a B20V build, Started to look at it and found this. I did not plan on taking it to a machine shop, just clean it up, lap valves and new seals/LMAs and what not. If I have to then that is whats needed. All advice is greatly appreciated. Sorry for the semi large/shitty phone pictures.
Old Nov 15, 2013 | 02:26 PM
93egSLEEPER's Avatar
Default Re: B16a2 Head..Can I fix this?
Ah man that sucks! The is possibly the worst spot to have some damage. That will create air turbulence and also create a hot spot.
You MIGHT be ale to find a machine shop to fill it and redo your combustion chamber and bowls, but probably a bigger headache than its worth. I hope you didnt pay big bucks for that thing.
You can tell by the weird carbon marks on the valve it's not allowing proper airflow/combustion.
Old Nov 15, 2013 | 02:38 PM
HatchSi's Avatar
Thanks, yeah I see what you are talking about with the carbon. I didn't spend too much on it thankfully. Hopefully 4Piston or any other reputable cylinder head shop can chime in and see if they can fix it for me. I'm in no rush as this is the beginning of the build so turn around time is not of importance.
Old Nov 15, 2013 | 04:52 PM
motoxxxman's Avatar
honestly, I'd just hit it with a flapwheel and smooth it out. it looks like it's just creating a hotspot, which will go away once smoothed out.
Old Nov 15, 2013 | 05:43 PM
F22Master's Avatar
Yeah, I would DIY that. Use a couple different bits on a small dremel. Shouldnt take long at all, and shouldnt hurt performance. Just dont touch the edge of the valve with any grinding stones. And you might as well clean and polish up all the chambers while you're at it.
90 integra da
Oct 23, 2012 09:13 PM
Got_soy
May 15, 2006 05:54 AM
Got_soy
May 9, 2006 07:17 PM
TougeCoupe
Jun 5, 2005 07:34 PM
KooK
May 22, 2003 07:23 AM
