any problems with H volume fuel pumps?
I just got a GREAT deal on a 340LPH stealth fuel pump that mounts into the OE assy. Will I have any problems with just wiring this fellow right in? Any complications do i have to change anything else around
Should work the same as your stock pump, When replacing mine in my 94 civic everything went back together great with the new pump(not OE but same style) Didn't make anything different, plugged in the same way.
lol no sorry it's a track car (time attack)....224whp N/A is pretty good. still haven't answered my question, if it's the car listed on your profile.....um no you don't need anything close to that especially considering the fact that you're still running stock injectors.
walbro/garms are both great brands.
How much psi bump your pressure at idle after install the Aeromotive stealth 340lph. Mine bump like 10psi at idle and I'm running 400whp and anyways have to lower it again to 52psi at idle.
Why do you use this pump? This is for the h22a4 with bolt on?
And you know you need to rewire that pump to get his full potential?
