Hi about to change head on my 1998 accord
this info is for 4 cyl model.
headbolts
step 1. 22ft lbs
step 2. tighten 90 degrees
step 3. tighten 90 degrees
step 4. (new bolts only) tighten 90 degrees
camshaft bearing caps.
6.0 x 1.0 mm..........................108 IN lbs
8.0 x 1.25 mm...........................16 ft lbs
headbolts
step 1. 22ft lbs
One more question my upper raditator hose keeps on getting super fast as soon as i turn the car on the when i open the cap so much air comes out i bleed the system but it develops so much air could this be the head gasket...i had the old raditor cap on their and it started foaming bubbles?????/ can u help me i just bought this car
and on top of that my brakes dont work i tried to bleed them and just a little of brake fluid came out i dont get it can any one help please!!!!
is your thermostat in place? is it new?
maybe have a partially clogged bleeder screw or like said above, clogged/ collapsed rubber, hard line.
toddhunter
Engine Machining & Assembly
May 27, 2019 08:19 AM
graveltravel2
Nov 1, 2008 07:55 PM
