crv mk1 brake warning light issues.
Please help have a 98 crv & the brake warning light stays on all the time. used to come on after 15mins but know is on all the time sometimes if I start car & is not on will only get 1 mile down road & will come on. have checked handbrake switch all is o.k & have checked fluid level all o.k. also disconnected cap but light still on!! any help appreciated kind regards lisa.
Sounds like part of your e-brake wiring is grounded somewhere. The light has 12v+ supplied to it all the time and when you pull the e-brake handle it sends the ground signal to illuminate the light. The downside is anywhere along the length of the wire that gets rubbed through and makes a ground would cause that. I'd try pulling the e-brake handle cover and unplug the wire, then see what happens.
long shot... happened in 2 of my Vs...
it was just the brake pads really thin, after i replaced them the brake light went away...
good luck!
good luck!
stellium
Jan 15, 2010 10:23 AM
shadow_ridge
Aug 11, 2005 10:35 PM
EH3Kid85
Sep 1, 2004 09:59 PM
