bc 300/300 stage 2 cams
What are you talking about? The cams aren't going to do anything for your compression. Static compression is just that...static. Switching cams will change the lift/duration of the valves, but has no impact on compression.
If you have stock internals, these cams are not for you. You dont just toss in a set of cams and go...there are a dozen factors that play into cam choice and you're getting ahead of yourself
First of all, which engine is this?
What is done to it?
What is your power goal?
What is done to it?
Ok guess i read a bad tread any way its a da9 with a b18a1 and ls trans and brian crower says the bc0022 n/a cams are safe i question this because a 300/300 seems way to much for the stock head this is not my car its a friends im buildind the g23 whole diff animal
Beat me to it^^^
OP just leave It stock...or boost it those guys who do all motor on a b18(non-vtec) are just as bad as the all motor/bolt on D-series guys, could still walk them with a b20V thrown together.
^^Exactly...the best thing you could do would be to swap a VTEC head. Its probably just as expensive as the cams, but will yield much better results.
Read this: https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/ <---I used this same thread to build my LS/VTEC back in the day
B16Civic93
Dec 30, 2004 06:53 AM
