engine swaps for ef?
Old Nov 13, 2013 | 08:10 PM
aarzate01's Avatar
Hey i have about $2700 for a nice engine, i was thinking of droping in a b16 engine in a ef hatch, would b16 be reliable? ? Or should i save up and get a gsr? Just want to knoe witch motor has a good amount of power and is reliable, right now i have a d15b2 non-v
Old Nov 14, 2013 | 05:04 AM
smilindave's Avatar
Default Re: engine swaps for ef?
My wife and I both have b16s in our efs. Mine is my daily, drive to work and back, run errands and the usual stuff an old married guy does. I find the engine to be reliable and reasonably fuel efficient. BUT most of all the most fun I have had since my 500 hp Mustang from the 70s. Mine is in a crx, my wifes is a hatch. Both are great fun and a suprise for the younger crowd in the area(white haired guy)
regards
dave
Old Nov 14, 2013 | 05:49 AM
Dark_Teg's Avatar
B16/b18A1/B18B/B20/B20Z/B18c1/B18C5/R----They are all very reliable.
For a nice budget friendly daily driver I would go B20Z.
If you want fast NA B18C5/R.
If you see boost in your future B16/B18C1.
Old Nov 14, 2013 | 07:01 AM
RanCRX's Avatar
B16 is easier to swap in if you get the 1st generation JDM B16a as it is obd0 wiring like your ef, but still needs some mods. But if you bump up to a newer b16 or b18 gsr stuff, then you are looking to spend well over $2700 just to get it in the car and running
Old Nov 14, 2013 | 08:39 AM
Freemananana's Avatar
B20Z is nice if you plan on keeping it factory stock. It has large displacement and will definitely get you around town fast. It should be very reliable too since it isn't that old.
I couldn't disagree more. OBD0 vs OBD1 as far as this swap goes is pretty ignorable. The OBD0 B16A distributors are hard to find. They run a pretty penny when you do find them, about $100. The OBD1 B-series VTEC distributors are a dime a dozen. I bought one for $30 shipped 2 weeks ago on here. Most go around $50. The ECUs also run about the same. PR3/PW0 will run you anywhere from $60-100 depending on who has them. They are less and less common. The OBD1 ECUs are very common and easy to find pre-chipped for around $75-100. No more than $120 and that should have everything set up for you. OBD1 is the most common platform right now and every ODB1 ECU can be converted to run VTEC or converted from automatic to manual. Then it's just chipping and burning the appropriate ROM for your motor. The conversion/jumper harness for OBD1 is also very cheap these days. The eBay harness I used was $40 shipped to my door, arrived in 2 days and the only confusing part was the extra wires that were optional. I would definitely say go with OBD1 over OBD0. You are already doing the DPFI to MPFI conversion and wiring VTEC. The extra hour to run OBD1 is definitely worth it.
$2700 for a NA engine swap is plenty. I can tell you what I spent on my swap:
"Full" Swap from HT: $1000
B16A OBD0 SiR I motor, 80k miles
SiR Cable trans
90-93 integra Axles and half shaft
Starter
distributor
alternator
HASport Mounts
ACT Clutch
Flywheel
B16A OBD0 headers
Shift linkage: $60 for DA or $130 for innovative B-series into EF, I did the $60.
OBD1 distributor: $30 on HT
P28 ECU: $75 on HT
Jumper: $40 eBay
DA integra spindles: $30 a side+shipping and $15 for new pads
Intake: can use stock but I got a new filter for $35 (K&N filter)
Resister box: $20
Total: ~$1500 because I did replace the headgasket and put ARP head studs in and a couple other things.
Originally Posted by Freemananana
Shopping List
This is everything that I had to purchase for my swap, most of this can be packaged if you go through a company such as Hmotors or a for sale ad in the marketplace.
1. Motor – Deciding on the motor is a key point in your swap. The B series motors ranged from the B16A, the original JDM DOHC VTEC, to the B18A1, Non-VTEC, to the B18C series swaps and even the B20 motor. The price ranged on all the swaps. Generally, higher displacement is better for boost and VTEC is good for staying NA. Your budget will decide which motor you should buy.
2. Transmission – Most of the B series transmissions are fine. The GSR and B16A transmissions have shorter gears, which is great for the drag strip and NA set ups. While the LS transmission has longer gears which can help build boost for longer durations and offers much more comfortable highway cruising. Note that you can build your own transmission and change final drives, gear ratios, ect. Note that many of these transmissions are cable driven, but some are hydraulic. The hydraulic transmissions will need custom work or the purchase of a conversion kit to work with the cable clutch of the EF Civic.
3. Basic Bolt ons – I am talking about the starter, alternator, Power steering, air conditioning, intake manifold and the distributor. These should all be easy to come by. They should be included with the motor most times and are easy to find at the junk yard if they aren’t.
4. Motor Mounts – The EF generation came with a D series motor. If you want the B series motor to fit you must buy custom mounts. eBay offers many choices, from Hasport to off brand. Used mounts are also a good choice. You will also need the rear mount bracket from a B series transmission if yours does not come with one.
5. Accelerator Cable – You need an accelerator cable out of an Integra. 90-93 should work. Automatic and manual accelerator cables are the same.
6. Clutch Cable – stock clutch cable will work just fine. You will have to loosen the mount on the B series transmission and push up on the pull arm to get the cable to fit, but it fits none the less. If you have a hydraulic transmission, you will need to fabricate or buy a conversion since the EF civic is cable driven.
7. Clutch and Flywheel – The stock flywheel and OEM clutch components will work fine. But replace the clutch, pressure plate, and throw out bearing while you have the motor out.
8. Water Pump and timing belt – Both of these are easier to replace with the motor out and are items that wear with time. Cheap insurance for a lasting motor
9. Radiator – The stock radiator will work perfectly for the B series.
10. Shift linkage – The shift linkage will have to be custom made. You can buy a premade shift linkage, but I would suggest buying the same brand motor mounts since they were designed together. eBay motor mounts and a hasport shift linkage may or may not line up.
11. Injectors and resister box – If the injectors are peak/hold, you need an injector resister box. If they are saturated, you do not.
12. ECU – It goes without saying that you need a new engine control unit. The ECUs for each motor are different and often you can buy ECUs chipped to run your motor. The P28 is a common ECU choice for the OBD1 motors. Note that the ECU and distributor need to share the same OBD code to be compatible.
13. ECU Pins – I suggest getting some spare plugs and/or a conversion harness. For anyone running a VTEC motor, regardless of OBD, you will need extra wires put into the ECU. And if you are running a DPFI model, you will need to add the extra wires to convert to MPFI for any B series swap.
OP, I would say any B-series swap is good. The D16Z6 swap is easy and cheap. But your budget of $2700 would lead me to suggest the F20B swap. I'm pretty sure it hasn't been done a whole lot. I've seen the motors go for $900. I think you have to get the F2B trans plate and then a B-series transmission. Motor mounts and a cut to fit shift linkage. But other than that, it's a lot like any other swap. And the F20B is about the same power as a K-swap.
Old Nov 14, 2013 | 08:45 AM
solorex's Avatar
Light flywheel and short ratio tranny is key here. If you are keeping the engine stock and reliable, you will enjoy the B20Z much more than the b16.
Old Nov 14, 2013 | 08:48 AM
Definitely agree. Well sort of. I love VTEC. I'm a fanboy. I'd rather drive my B16A around then any non-VTEC motor. Anyways. The B20Z with some half decent headers/exhaust and the B16/GSR trans would be very nice for a daily. Don't do anything to the motor aside from that and it will be very very nice. I believe they only rev to 6500 RPM or so though. But they make more torque than a B16. And that's just about all that matters when you're driving in the city.
Old Nov 14, 2013 | 01:31 PM
aarzate01's Avatar
Thanks for the tips ! Helps alot
Old Nov 14, 2013 | 01:53 PM
4drEF's Avatar
Keyboard Humorist
Reliable?
On a used engine?
Impossible to tell.
Old Nov 14, 2013 | 02:27 PM
Originally Posted by 4drEF
Reliable?
On a used engine?
Impossible to tell.
That is true. You can only guess and try and see if there is anything wrong with the motor.
Old Nov 15, 2013 | 02:49 PM
aarzate01's Avatar
Im going to get the engine from a shop with 45k miles on it going with the b16
Old Nov 15, 2013 | 06:27 PM
1991CIVICHATCH's Avatar
I am doing a b18 in mine now.
Old Nov 15, 2013 | 07:34 PM
91turbosohc's Avatar
Save some money and keep it sohc. www.d-series.org for more info...
Old Nov 15, 2013 | 09:09 PM
hersheyulr's Avatar
Old Nov 16, 2013 | 02:40 PM
Not dissing the B16, I love mine, but a lot of people complain it's not that big of an upgrade.
After having a DOHC I will say the only SOHC I will swap in would be the J-series. The D-series motors are cheap but I don't think it's any cheaper in the long run. If you plan on boosting it is really a hindrance to use the D-series blocks. But! Before this becomes some sort of debate, the OP did say he is going with a B16 already. So I guess it's done.
OP, if you need OBD0 parts for your B16 send me a PM. I have a distributor and 2 ECUs from my OBD0 B16A I am trying to sell.
Old Nov 17, 2013 | 04:36 PM
dopesk8er87's Avatar
B16a FTW I can't wait to get mine :D
Old Nov 17, 2013 | 10:07 PM
Glowicki's Avatar
I love my b16a. It's a ton of fun, it's an easy swap.
Old Nov 18, 2013 | 01:38 AM
DCRB's Avatar
both are reliable, if you don't mind a slight drop in fuel economy i'd go with the b16 and convert to obd1, because parts are easier to find for obd1/2 b series swaps, and most shops wont tune obd0
b16's, while it is true the don't make much more power than their sohc counter part, are more boost friendly and respond better to NA bolt on mods. you can reliably make 300whp all day on a stock healthy b16, and in our cars that's WAY more than enough power for street
Old Nov 18, 2013 | 04:07 AM
Very true. I still get mid to high twenties (25~28 mpg) on my B16A around the city. I assume I probably get closer to 35 on the highway. And that's fine for me. I don't drive very far.
I definitely agree with the second part. They have more room to expand in the future than the D-series does. And the DOHC is definitely a break through as far as the engineering is concerned. For about $5,000 you can put a B16 in your EF and boost it to 300 whp. That's what I did and that included the orginal cost of the car ($1500).
Old Jul 25, 2020 | 07:01 PM
Envyous15's Avatar
I currently have a 89 civic dx sedan and I have the original D15b and I was wondering if doing an H series swap or B18c but leaning more towards the H23a just want to know what do I got to do to make it possible for that swap
Jl91
Feb 10, 2015 12:37 PM
flatblackhatch
Sep 1, 2006 02:33 PM
flatblackhatch
Sep 1, 2006 01:14 AM
Red_Si
61
Jul 17, 2004 10:54 PM
coldcrx
Oct 21, 2003 08:45 AM
