Extremly high idle b16a
Old Nov 13, 2013 | 08:09 PM
Glowicki's Avatar
Default Extremly high idle b16a
So, I put a b16a swap into my crx Dx about a month ago. It had a high idle and I was barely able to get it down to 750rpm after it warmed up. My problem now is, the idle screw is adjusted as low as it will go and after the engine warms up, it idles around 2000rpm.
Is my tps at fault? If so, how would I check to see if it is the problem?
Old Nov 13, 2013 | 09:12 PM
Glowicki's Avatar
I may have found what was wrong. I just watched a YouTube video from Eric the car guy on another thread, then another video, then another video, (you all understand how easily distracting YouTube is) and stumbled upon one where he adjusts his throttle cable. It now seems as if my cable is a little too tight. I'll adjust it tomorrow and report back.
Old Nov 13, 2013 | 10:24 PM
jpciii's Avatar
Default Re: Extremly high idle b16a
Clean out or replace the idle air control valve (IACV). Also make sure there are no vacuum leaks.
Old Nov 13, 2013 | 10:33 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
I concur on everything that has been said thus far.
Old Nov 14, 2013 | 04:57 AM
Freemananana's Avatar
Yeah, IACV is likely the cause. Or vacuum leaks. Both are easy to clean/fix. Also look at the FITV if your B16A has one. Eric the Car Guy is pretty good for little things. My B16A idles at about 1500 until it warms up. But 750-850 is fine for a warm idle.
Old Nov 14, 2013 | 05:44 AM
Glowicki's Avatar
I can't seem to find the iacv for fitv on my intake mani. I'll post a pic in a bit.
Old Nov 14, 2013 | 05:48 AM
Ferio Wdm Edition
Iacv is on the back of the manifold, the fitv should be underneath the throttle body.
Old Nov 14, 2013 | 06:02 AM
Glowicki's Avatar
Old Nov 14, 2013 | 07:49 AM
jpciii's Avatar
The IACV is the cylinder shaped thing on the back of the intake mani in your top pic. Its function is to allow some air to bypass the throttle body (basically creating a small controlled vacuum leak) to bump up the idle speed... like when the AC is on, for instance. They can get gunked up inside and want to stick open. That part is on a lot of Hondas. Do a search on cleaning them out. It is a very common pest regarding idle problems.
Old Nov 14, 2013 | 08:12 AM
Furthermore, the FITV should be under the throttle body. That is basically where the intake meets the tube that goes to the air box. Also very common on these hondas and is also very easy to fix.
Old Nov 14, 2013 | 05:44 PM
Glowicki's Avatar
I found a couple write ups on here on how to clean both. I'll have to tackle them this weekend.
Old Nov 15, 2013 | 06:11 AM
zrickety's Avatar
You will probably find the FITV is unscrewed. Screw that puppy all the way in and your idle should drop. If that's not enough, someone may have adjusted the base idle screw on the bottom. There is a whole procedure to set that and the TPS. Good luck.
Old Nov 15, 2013 | 11:02 AM
Glowicki's Avatar
If you could post the process, that would be greatly helpful. I had adjusted about two weeks ago, but it didn't help.
Old Nov 17, 2013 | 05:14 AM
zrickety's Avatar
You will have to search for the procedure, I don't remember the details. You might have a vacuum leak too, have you changed the intake or TB gaskets?
Old Nov 17, 2013 | 05:50 AM
HondaPartsHero's Avatar
Technical Hero
If you've checked for no vacuum leaks follow these in this order (DO NOT adjust the base idle screw):
Clean IACV
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
Clean FITV
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
Adjust throttle cable
http://www.hondacivicforum.com/forum...ed-help-60115/
Adjust idle
http://crxcommunity.com/viewtopic.php?f=4&t=10686
Old Nov 17, 2013 | 10:39 AM
Glowicki's Avatar
Thanks for the info, I'll have to take a look at the car when I get a chance. I should be able to in the next week or so.
Old Feb 27, 2014 | 07:35 AM
Glowicki's Avatar
I know I haven't replied in a while. About a month or so ago I cleaned out the fitv and iacv an that fixed the high idle.
After I drove the hell out of the car to school yesterday, the idle is right back where it was before I cleaned the fitv and iacv.
I'm going to clean them both put again next week. I was just wondering what would cause the idle to jump back up to 3000 rpm when it was 750 rpm the day before.
Old Feb 27, 2014 | 09:32 PM
TeamRedline89Hatch's Avatar
3000 rpm, I'd say vacuum leak.
Check your throttle cable to see if it is too tight also.
Old Feb 28, 2014 | 04:42 AM
Glowicki's Avatar
I'll check for some vacuum leaks when I get a chance. The throttle cable is already adjusted properly.
Old Feb 28, 2014 | 04:56 AM
Fliptard's Avatar
not trying to highjack, but my A6/Z6 idles at 2K as well, cleaned the IACV and that's not the issues, idle screw is all the way it. Have adjusted the cable, and tightened the FITV. Have checked for vacuum leaks with break clean and propane with nothing found.
apbtwhiskey
Mar 20, 2013 09:39 PM
aojtin
12
Oct 10, 2008 06:11 PM
ekb16
Apr 26, 2006 07:47 AM
Irish Integra
Mar 31, 2005 02:30 PM
