How to hook up PS and A/C in my gsr?
Old Nov 13, 2013 | 12:40 AM
DylanGSR_eh9's Avatar
Default How to hook up PS and A/C in my gsr?
So in my 4 door I have no PS or a/c, and its my dd and I want to put that stuff in it to make it a more comfortable riding car, I have nothing in the car for that stuff and any help and tips are appreciated.
Old Nov 13, 2013 | 03:39 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: How to hook up PS and A/C in my gsr?
?? What kind of car? What is missing?
Old Nov 13, 2013 | 03:44 AM
DvrkLord's Avatar
Honestly the best thing would be to do it go find a teggy at a junk yard and pull power steering pump, res and everything you need, most are still in good condition. As for A/C same thing. Most likely will have to get a recharge done it. just make sure all the lines are good. Hopefully your car still has most of the **** to make it an easy hook up.
Old Nov 15, 2013 | 12:03 AM
Sorry its a swapped eg sedan with a gsr swap, and my car has the hoses for PS just not the pump/reservoir, and I pretty much need to do a/c from scratch.
Old Nov 15, 2013 | 06:06 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
As far as the ac you need a USDM b20 ac bracket or one off a del sol vtec. This allow you to use the ac components including compressor for your civic. Only thing you need to know is if your car is r-12 or r-134 since 93 used both during that year. Do you have any ac components under your dash
Old Nov 15, 2013 | 07:23 AM
B serious's Avatar
Use a 94-01 integra PS pump. Use a 1st gen CR-V A/C bracket if you want to use your original D series compressor. Or use a integra/b16 AC bracket if you want to use a B series compressor and AC hoses.
Old Nov 16, 2013 | 12:09 AM
As far as a/c components I do not know, I will look into it tomorrow but the car did come with a/c before I got the shell, I appreciate all the info guys! It helps alot
Delsol-Yuuup!
Apr 26, 2012 05:38 PM
DOHCter VTEC
Feb 16, 2009 05:00 AM
raidacaipo
12
Jul 11, 2008 06:57 PM
ssd
May 6, 2006 06:19 PM
madman604
May 5, 2003 01:09 PM
