Starter issue!
Old Nov 12, 2013 | 09:09 AM
fin781's Avatar
Default Starter issue!
This has been an on going thing.
Sometimes it starts right up. Most the time
I have to rock back and forth in gear to start it.
Starts everytime if I jump the starter with a wire.
Has anyone dealt with this crap before.
Car is a 1990 crx. Gsr swap. Did same thing with previous LS.
Replaced starter with one I had laying around.
Connections seem tight and secure. No corrosion.
Any other leads would help. Possibly ignition switch?
It's an annoyance more than anything. Thanks homies.
Old Nov 12, 2013 | 09:18 AM
instrument's Avatar
Default Re: Starter issue!
clutch relay switch tested?
Old Nov 12, 2013 | 09:30 AM
fin781's Avatar
The original owner I guess bypassed it.
If referring to pushing in the clutch to start.
The clutch does not have to be pressed to start.
Haven't considered that being an issue. Think that could be it?
Old Nov 12, 2013 | 11:41 AM
EF_Avery's Avatar
If he did a crappy job of bypassing it, that could be it OR it is the plug that the 12v wire goes into on the starter. I spent a year hot wiring or compression starting my car because a wire on the inside of that plug broke and always thought it was my ignition switch. Every time I hot wired it, it would make enough contact to start. Then one day I was messing around and the whole thing came out of the starter housing lol But you replaced the starter so I would assume clutch switch first.
Old Nov 12, 2013 | 12:43 PM
4drEF's Avatar
Keyboard Humorist
Possibly ignition switch making weak or intermittent contact.
Old Nov 12, 2013 | 01:06 PM
F22Master's Avatar
This.
Black R
Apr 8, 2023 07:14 AM
deucedeuceEK
Jul 21, 2015 10:32 AM
siblues
Oct 2, 2014 11:25 PM
Honda_Mane
Jun 10, 2011 10:16 AM
