99 Civic Ex won't start after stolen
Old Nov 11, 2013 | 06:03 PM
canabiscris's Avatar
Icon6 99 Civic Ex won't start after stolen
I have a D16y8, my car recently got stolen. Aside from cosmetics, it appears they stole the following engine components: Cold Air Intake, Distributor, and Plugs. It's not much, I replaced it all; however my car wont start. I have fuel and spark... not sure about compression? So basically I want too know if their is some type of component they stole and would inhibit my car from starting and might have over looked.. or if the ******** blew my motor... any advise????? help
Old Nov 11, 2013 | 06:08 PM
jbpnoman's Avatar
Default Re: 1999 Honda Civic Ex
Is your ECU still there?
Old Nov 11, 2013 | 06:13 PM
yeah, it doesn't look like anything was cut. I had a chipped one and harness..... they stole that.
Old Nov 11, 2013 | 06:16 PM
jbpnoman's Avatar
But you still have an ECU plugged into the car, down at the kick panel? Have you checked timing? Compression test?
Old Nov 11, 2013 | 06:38 PM
yeah I have the stock ECU, and I haven't been able to do a compression test because car wont start. I think there is a tool I can rent? was planning on that tomorrow. I did the timing several times
Old Nov 11, 2013 | 07:28 PM
Marvin1985's Avatar
You double check plug wires? Make sure you plugged em in right
Old Nov 11, 2013 | 07:47 PM
ewilliams1990's Avatar
Is it cranking? Check distributor position.
Old Nov 18, 2013 | 10:51 AM
Default Re: 99 Civic Ex won't start after stolen
all the plug wires are new and in the right order, and yeah its cranking but wont start.... it seems like it wants to start but it just isn't starting.
Old Nov 18, 2013 | 11:31 AM
Grape Ape Guy's Avatar
could the distributor be put in 180 deg out?
Old Nov 18, 2013 | 05:10 PM
jbpnoman's Avatar
No, Grape, they're keyed to prevent that from happening.
canabiscris
Nov 18, 2013 10:53 AM
Happiest92Ricer
12
Jun 28, 2013 08:52 AM
bdmlilburn
Oct 5, 2011 08:10 PM
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
mugenracer
May 19, 2002 02:29 PM
