FS: 1991 Honda Civic DX Sedan
Maintenance:
Parts included:
*Will be sold on oem steel wheels with tires and include only what is listed above. Most of the parts in the following pictures are either sold or not for sale.
$4500
located in pomona
call/text 94nine-94three-491one
- Purchased in May 2008 completely stock
- Clean title
- Pink slip in hand
- Registered until May 2014
- 227k mi on original D15B2 (completely stock/never modified)
- 5-speed manual
- Clean black interior
- Passes smog
- Runs great
Maintenance:
- Paint job in June 2008 (original color, OEM '91 charcoal gray, color sanded twice and garaged and under a car cover ever since)
- Timing belt service with OEM parts (belt, tensioner, water pump, all gaskets/seals, etc.)
- New windshield and OEM weather strip
- New oil pan and OEM gasket
- New oil and filter
- New OEM spark plugs
- New OEM air filter
- New OEM fuel filter
- New OEM motor mounts
- New Exedy OEM replacement clutch
- New front & rear rotors/pads
- Fresh DOT3 brake fluid
- New bulbs all around
- New OEM replacement radiator and fresh coolant
- New battery/battery tray/OEM tie-down/quick disconnect
- New rear trailing arm bushings
- New OEM speedometer cable
Parts included:
- JDM EF2 front end (fenders, sidemarkers, hood, bumper, factory lip, filler, grille, 1-piece headlights, core support)
- Complete black interior (swapped from a red sedan)
- OEM front/rear mudguards
- EDM lower center console
- OEM Honda CD player (from S2000)
- Rallye 5-panel mirror
- Skunk2 Pro-S full coilovers
- Skunk2 front camber kit
- Skunk2 rear camber kit
- Energy Suspension motor mount inserts
- New OEM emblems
- New OEM door moldings
- GSR rear trailing arms w/ disc brakes
- 40/40 proportioning valve
- Energy Suspension shifter bushings
- EDM black lower center console
- Custom fit NOAH car cover
$4500
located in pomona
EViLSTAR
Apr 5, 2008 05:18 AM
EViLSTAR
Mid-Atlantic (Sales)
13
Apr 5, 2008 05:16 AM
