rear brake conversion question
Old Nov 11, 2013 | 12:44 PM
xyouthcrewx's Avatar
Default rear brake conversion question
I know I'm going to get some slack for not looking this up in the Faqs, but I'm already confused enough as is. This is my first honda project and I'm very new to cars and learning as I go.
I just bought a 91 ef that already had the conversion. I desperately need new brakes, but I'm unsure what year to buy the integra rotors, calipers and brakes. I don't know if it matters but i'm assuming 90-93.
I'm not sure what is on the car, trailing arms or any of that. i just know on the sheet i received from the previous owner it states "rear integra disc brakes".
Old Nov 11, 2013 | 02:26 PM
radex7's Avatar
Default Re: rear brake conversion question
I am on the same boat as you my friend, I dug around a bit, compared parts numbers and interchange part numbers, and what I came up with is this:
http://www.ebay.com/itm/310566543963...84.m1438.l2649
As long as they ARE from DA integra these should be fine.
Now, get on Acura parts website, get the parts numbers for both calipers, and google away!
So the car you have came with a partial swap? just the trailing arms and nothing else there?
Old Nov 11, 2013 | 07:33 PM
EFmine's Avatar
safest way, just take off your pads and take them to the autoparts store. ask for DA and DC and see which one matches
Old Nov 11, 2013 | 07:45 PM
10psiLsEf2's Avatar
Look at the trailing arms and look for a number like pr3 pr4 etcetc.
Old Nov 11, 2013 | 08:26 PM
Riceburner247's Avatar
Since you're not sure of what you have at all, it would probably be a good idea to get under there with a flashlight and get part #'s off the trailing arm, brake caliper, rotor, pads, anything. That way you KNOW what you have. You never know when you'll need wheel bearings, bushings, end links, etc.
Old Nov 12, 2013 | 06:50 AM
Thanks for the tips. It just snowed here, so now I get the pleasure of freezing and looking at part numbers! haha.
I'm not totally sure of anything on this vehicle at this point. It's a mismatch of everything. I wish people would keep a more accurate detail of the parts they swap on their cars not only for themselves, but even more so if they think in the future they might sell it.
Boo$ted
Suspension & Brakes
Sep 25, 2012 09:24 AM
UnKnOwNsLeEpEr
Jul 26, 2005 08:03 PM
gray89si
Aug 10, 2004 01:27 PM
LowFlyin'
Oct 20, 2003 03:49 PM
JediPimpCrx
Sep 5, 2002 01:02 PM
