Custom Intake manifold - Injector placement.
Hey all,
I was wondering if there is a golden rule or maybe even a way to optimise injector placement in an intake manifold.
The intake in question is being built for a turbo conversion engine. I didn't know if there was a way to determine the best placement and if going forced induction made a difference on injector placement.
Matt
Matt
Best bet is to have the injector spray hit the back side of the valve. Anything else will hit the intake walls and form into larger droplets which don't burn well.
as close to the intake port as possible. or if there is the little provision in the intake port where the factory injector tip protrudes into (like in the B series heads) than use that
Best best is not do anything said as if it's definite way....
Grab some fluid mechanics books on the fluid you're working with, do bench test and simulations on CFD.... and find the optimized spot for your setup.
Back of the valve is only good for idle.
Probably on the back wall of the plenum with each facing the corresponding runner opening. LOL. That would be my guess for maximum power.
Who is Mr Robot?
I've also wondered if there's some magic formula to figure out how to change the injector firing event timing(crank rotation in degrees, where it opens initially) when you move the injector away from the port
My primaries will probably be 2-3 inches further back than the stock location and my secondary shower injectors will be close to 6-8 inches from the port/valve (mounted to the plenum, inline with the port and centered to the runner opening
I just need to figure out how to properly time the opening of the secondary shower injectors so the fuel won't slow down and have time to cling to walls.
I'm also doing direct port water/meth injection with my itbs (meth injected post butterflies) need to figure out the best nozzle style and minimum distance from port/valve for complete atomization
sorry for the thread jack but I thought it a proper question given the topic
Who is Mr Robot?
yea I know, it's just figuring out how much to change the injector timing for both primaries and secondaries.
I thought I saw some sort of math formula somewhere a while back but I cannot remember it for the life of me
