Is that sound deadening under the carpet?
Old Nov 11, 2013 | 06:48 AM
BlackJacket's Avatar
Default Is that sound deadening under the carpet?
While removing the interior of my eg sedan, I noticed what looked to be factory sound deadening. It was flaking up pretty bad so I removed all of it. What can I replace them with and what the heck is the name so I can Google efficiently.
Old Nov 11, 2013 | 07:01 AM
instrument's Avatar
Default Re: Is that sound deadening under the carpet?
sound deadening material, I mean you just answered your own question...so...
you could use dynomat...or something equivalent...or if youre cheap spray that undercarriage stuff.
Old Nov 11, 2013 | 07:14 AM
dirty19's Avatar
Ridin Dirty in Cali
Be careful in spraying undercarrige stuff in there. you want stuff that actually adheres and doesnt crack or fall apart when stepped on.
I believe 3M makes a good one.
Old Nov 11, 2013 | 07:18 AM
Yea... lol.
I should have said is there a factory part # or can I replace it with something else.
Thanks for the help!
Old Nov 11, 2013 | 08:24 AM
EsotericImage's Avatar
Retired Moderator
I could just inagine the small after spraying that stuff..
Old Nov 11, 2013 | 08:38 AM
Yea I think I'll stick to Dynamat or something similar.
Old Nov 11, 2013 | 09:33 AM
TripleLude's Avatar
Make all the grommets are in place before you put anything down. Nothing worse than getting water under there after adhering sound deadening materials.
Old Nov 11, 2013 | 10:20 AM
jbpnoman's Avatar
Dynamat is overpriced for what you get. There are plenty of better sound deadening options out there. Do some research.
Old Nov 11, 2013 | 11:03 AM
purgat0ry's Avatar
Dynamat is on the same caliber as rockford fosgate stuff IMO, over priced, great marketed garbage.
3m is the way to go IMO, just be sure to do all of your research now.
Old Nov 11, 2013 | 12:55 PM
TripleLude's Avatar
3M Products have always been top-notch for me.
Old Nov 11, 2013 | 02:33 PM
The floor pan is looking great. Everything is where it should be and no rust! I'm going to give it some fresh paint and then cover it with some deadener of some sort. Seems 3M gets high praise so I'll check into that.
alexm
Audio / Security / Video
Apr 17, 2009 04:10 PM
vandersmissenc
Dec 13, 2006 01:06 AM
SoloSol
Nov 8, 2003 08:21 PM
AK94GSR
10
Nov 19, 2002 02:18 PM
