JDM ITR PCV valve
Old Nov 11, 2013 | 05:08 AM
dc2 specR's Avatar
Default JDM ITR PCV valve
Hello i think my pcv valve on my jdm itr is clogged and it needs cleaning. If the carb cleaner cant do the job i might as well replace it. Problem is on our country we only have pcv valves for a b16a and a B20. Is the b16a pcv valve same as the ones on our itr? If not then what would be its equivalent?
Thanks in advance
Old Nov 11, 2013 | 05:11 AM
JuggerNaut-CTR's Avatar
Default Re: JDM ITR PCV valve
They are the same. Most of the replacement parts I would buy were from a b16. I.E. gaskets, filters, ignition parts, as well as the pcv valve.
Old Nov 11, 2013 | 07:00 AM
TypeRod's Avatar
Thanks in advance
Hey Pare'! Kamusta?! Are there many Type R's in your part of P.I.?
Old Nov 11, 2013 | 07:25 PM
dc2 specR's Avatar
JuggerNaut-CTR : Thanks for the tip sir will definitely buy a new one
TypeRod : Boss kamusta dyan? yup! thanks sa port of irene and cebu. Madami naka dating na Orig Type R dito sa atin from DC2 Type R,DB8 Type R,DC5 Type R to EK9 Type R. Madami din S2000s and even an NSX. But we have to convert pa to LHD kasi only LHD vehicles are allowed here dito sa atin.
Old Nov 12, 2013 | 05:35 AM
TypeRod's Avatar
Mabuti naman! lol! Forgive me pare', my Tagalog is not very good. I'm an EOP (English only Pilipino) lol! But I can understand an ok amount of Tagalog. Wow, its so cool to hear about the Honda scene in your part of P.I. Good luck to you! Ingat!
Old Nov 12, 2013 | 05:50 AM
Dekorum's Avatar
Actually most of the replacement parts I buy for my JDM ITR are from the 97 USDM ITR. I replaced the PVC valve last week using part number 17130-PM6-G01, which is for a 97 USDM ITR.
For a 99-00 USDM Si, the part number is 17130-PM6-003. I wonder if they are any different? I am not sure sure which one is correct. Mine seems to be running fine, but maybe not as perfect as it could with the Si PCV?
talkJDM
Suspension & Brakes
Jan 6, 2009 03:07 PM
Rishiras
Mar 28, 2008 02:31 PM
itrhatch
Mid-Atlantic (Sales)
Nov 28, 2006 09:59 PM
evo
Oct 4, 2002 12:09 PM
