Spark plug wires d-series mini me.
Old Nov 10, 2013 | 08:11 PM
Douglasjdm's Avatar
Default Spark plug wires d-series mini me.
Hey guys I got a quick question. So I did a mini me swap on my car and my block is d15b7 and the head I put on is d16z6 and it didn't come with distributor so I had to buy one separate a vtec one but it was only the distributor and didn't come with spark plug wires. Can I use my d15b7 spark plug wires or do I have to buy some for a 95 civic Ex that's the car I took the head off of and put it in my 95 civic LX so that's my question because I think the head I have is a d16z6 but it has a d16y8 valve cover is that why the spark plug wires don't fit all the way in? But they click just fine into the spark plugs
Old Nov 11, 2013 | 07:50 AM
hondamark35's Avatar
Default Re: Spark plug wires d-series mini me.
Z6 and Y8 have virtually the same valve covers. the difference is the design of the head between the B7 and Z6/Y8. since they click in place you should be able to run with them. but, to get a good seal and keep stuff out of the tubes, and look normal... you need wires for a Z6 (92-95 EX).
Old Nov 11, 2013 | 10:23 AM
Ej1coupe3's Avatar
What he said ^^ z6 wires have you started the motor yet?
Old Nov 17, 2013 | 01:54 PM
Douglasjdm's Avatar
No I haven't started the motor it won't start ?? Idk what it is. It cranks but won't turn over what could it be ? Everything is hooked up
Old Nov 17, 2013 | 02:11 PM
Trevor123456789's Avatar
Check grounds.
92lxsleeper
Jun 6, 2009 08:05 AM
d15nonvtec
Sep 23, 2003 08:53 PM
crooked muffler
Mar 23, 2003 06:27 PM
