ZC worth the questioning?
Old Nov 9, 2013 | 04:42 AM
F22Who's Avatar
Default ZC worth the questioning?
I recently picked up '89 civic dx hatch with a DOHC ZC in it. Here comes the headaches.
The motor needed some love (timing belt had a good gash in it, valve cover leaking... nothing too crazy, regular maintenance). Headed to my local automotive store to pick up the parts and found out just how confused I could make them. The first individual I talked to, asked me what parts I needed and then did the normal "and what vehicle is this for?" so with a big sigh for the on coming battle that I knew was about to ensue, I told him an '89 civic dx......but its not the stock motor. It has the 1.6 DOHC ZC in it. I'm pretty sure I watched his brain implode.
His solution was to go look at my car and take a look for him self, which is their way of telling you that you have no idea of what you are talking about. He takes a look and mumbles some stuff out loud to him self and then nods his head like he knew what I was talking about from the get go, and headed back into the store. He mashes away at his keyboard and eventually looks at me and asks if I could do some research and find out what the OEM part numbers are and he would be able to find them for me.
My question comes down to, Should I just keep on hand one of the many parts list that are on a few of the threads here, or is there an easy way of avoiding the look of despair that I encountered that day? Should I leave the ZC in it, or switch to something a little more commonly known? (I thought they were pretty known). I've never had a ZC setup which was one of the reasons the car called out to me, I like to learn about new setups (new to me).
Any input is greatly appreciated or any of your past experiences with obtaining parts. (easiest way or ways to avoid )
Old Nov 9, 2013 | 04:46 AM
F22Who's Avatar
Default Re: ZC worth the questioning?
Old Nov 9, 2013 | 05:24 AM
CWBETB's Avatar
www.thezcr.com
Alot of ZC info on here just need to dig a bit.
Pretty much a DOHC ZC is a sohc Si engine + Prelude engine+ Teg engine, all mixed in one. All the parts are available just need to get them from other models
DOHC ZC parts list
DOHC ZC Parts & Aftermarket Parts List
**Pipe in and reply If anyone has SOLID INFO I will not edit it with hearsay or I *think* replies, We need a good list stickied for all the members who ask whats what and what do I use.
Part Part Number Application Vendor Notes
ODB0 Distributor TD03U 88-89 Integra .
ODB0 Distributor Cap 30102-PM7-305 88-91 CRX Si/88-89 Integra OEM .
. JP936 . WELLS .
. 44-9620 . VALUCRAFT .
. JP936G . GOLD .
. 8290 . MSD w/Coil Bypass .
OBD-1 Distributor Cap and seal
1994-2001 Integra LS & RS B18 non vtec models.
OBD-1 Distributor Cap part #
OEM Acura - 30102-P54-006 -- listed price through Majestic Acura is $21
Distributor Cap gasket
OEM # 30132-PM5-A02
Rotor Button
88-91 Civic/CRX // 88-89 Integra
Brand-----Part#
OEM - 30103-PM5-A05
WELLS - JP923
VALUCRAFT - 33-8220
Spark plug wires
88-89 Acura Integra
Spark Plug Wires
Brand-----Part#
OEM -
MSD - 32339
MAGNECOR - 45125
NGK - NGK-HE48
NOLOGY - 011014011
**If not going for High performance wires USE OEM all others are inferior except for performance wires.**
Spark plugs
Dont waste your money on platinums or iridiums
NGK is standard from Honda. If your Boosting the motor choose your type carefully as a standard plug is not for you, you will need a colder plug.
Spark Plugs
88-91 Civic/CRX si 1.6L // 88-89 Integra
Brand-----Part#
NGK V-POWER - BCPR6E-11
Spark plug tube seals
86-89 Integra
OEM # 12342-PT2-000
Distributor O- ring and CPS O-ring
88-89 Integra
OEM # 30110-PA1-732
Oil Filter
The S2000 OEM Filters will work also and are made by a reputable company in Japan that makes high performance oil filters, but you will pay more for them.
MY Suggestion...Get OEM Its only a couple bucks so why buy others when you can have a OEM filter for mostly the same price.
Oil Filter
Brand-----Part#
OEM -
STP - S2808
FRAM - PH6811
K&N - HP-1004
MOBIL - M1-104
Cylinder Head Gasket
1988 & 89 Integra
Brand-----Part#
OEM - 12251-PM7-003
FELPRO - 9451PT-1
HKS GROMMET - 2302-RH001 (0.7mm Thick/76mm Bore/9.9 CR)
HKS BEAD - 2301-RH010 (0.6mm Thick/76mm Bore/10 CR)
Head StudsARP
Part # ARP 141-4204 Dodge Neon SRT-4
Head Studs
Brand-----Part#
ARP - ATP6.760-1lb ?? * needs verifying for 100%
Intake Manifold Gasket
1988 & '89 Integra
Brand-----Part#
OEM - 17105-PG6-S00
FELPRO - MS93362
IACV (Intake Air controll valve)
88-91 Civic/CRX
oem # 36455-PT3-A01
Exhaust Manifold Gasket
1988 & '89 Integra
Brand-----Part#
OEM - 18110-PG6-003
FELPRO - MS93363
Rear Main Seal
1988 & 89 Integra
Rear Main Seal
Brand-----Part#
OEM - 91214-PH1-013
Front crank seal
1988-89 Integra
Front Crank Seal
brand-----Part#
OEM - 91212-PEO-662
Cam seals
1988-89 Integra
Cam Seals
brand-----Part#
OEM - 91203-PG6-013
Oil Pan
88-89 Integra
Oil Pan
Brand-----Part#
OEM #
Oil Pan Gasket
Brand-----Part#
OEM - 11251-P01-004
FELPRO - OS30542R
ROL - OS5725
Header
88 - 91 CRX/Civic Headers will fit. The ports are off just a tad but the bolt pattern is money. Nothing a little grinding can't fix.
Timing Belt
1988 Prelude 2.0 Si.
Timing Belt
Brand-----Part#
OEM - 14400-pk2-004 NOTE:I have heard people get part #14400-pk2-003
they should be the same
Timing belt tensioner
OEM part # 14510-PM7-004
Engine and tranmission Mounts
1988 - 1991 CRX/Civic (All trim levels)
Engine and transmission Mounts
Brand-----Part#
OEM - 50810-SH3-040 (Rear, Firewall Mount)
OEM - 50805-SH3-040 (Transmission Mount)
OEM - 50821-SH3-040 (Side Mount, By Timing Belt)
OEM - 50840-SH3-000 (Front Mount)
CPS (Cylinder Position Sensor)
1988 & 89 Integra 1.6l
Brand-----Part#
OEM - 37841-PG7-006
Transmission
Any 88-91 L3 transmissions will work.
**See below for more info**
Throttle Body
88 - 91 Civic/CRX Si 1.6L
Throttle Body Gasket
88-91 Civic/CRX Si 1.6L only
Brand-----Part#
OEM - 16176-PM6-S00 or 16176-PM6-000
Radiator Hoses
*Upper: 88-89 Integra
*Lower: 88-91 Civic/CRX
Radiator Hoses
Brand-----Part#
OEM Lower Hose - 19502-PM3-000
OEM Upper Hose -
Valve cover Gasket
86-89 Integra
Valve Cover Gasket
Brand-----Part#
OEM - 12341-PM7-000
86-89 Integra
Valve cover stud Grommets
90-93 Integra 1.8L
**OEM part # 90442-PR3-000
Valve Cover Studs (outer and 1 in Center)
1990-93 Integra B18, 97-2000 CR-V B20
Valve cover Studs
Brand-----Part#
OEM - 90012-PM7-000 (this is the outer ones)
OEM - (I need the inner stud part #)
Thermostat
88-91 CRX/Civic
Thermostat
Brand-----Part#
Stant OEM TEMP - 45878
Prestone OEM TEMP - 392180
Alternator
88-91 CRX/Civic
Alternator
Get a NAPA if you must use other than OEM, but try to stay OEM here if you can. Advance and Autozone and most other parts stores Have VERY LOW quality replacements...**Why do you think they have to offer a lifetime warranty??..( a little something to make you think)
Brand-----Part#
OEM - 31100-PM8-A03RM or 31100-PM8-A03RMD
Water Pump
88-91 CRX/Civic
Water Pump
Brand-----Part#
OEM - 19200-P01-003 or 19200-P01-004
Water Pump Gasket
*If your gasket is leaking You might as well get a new pump and it will come with the gasket*
Oil Pump
88-91 Civic/CRX
OEM # 15100-P06-A01
Fuel Injectors
88 - 91 CRX/Civic Si / 86-89 Integra
Fuel Injector
Brand-----Part#
OEM - 06164-PK2-010
BOTTOM END components
connecting rods
But any D-series 1.6L rods will work for upgrading.
Pistons
88-89 Integra OEM
There are many companies that offer ZC specific Pistons now, so Aftermarket is there.
Main & Rod bearings and thrust washer bearings
Piston Rings
88-91 Civic/CRX // 86-89 Integra
**Transmission quirks**
88 Transmissions are the only ones that are 21 splined
That means you must use a 88 ONLY clutch kit.
89-91 Transmissions are all 20 spline.
Old Nov 9, 2013 | 05:30 AM
F22Who's Avatar
Cool, thank you. Best bet sounds to be just holding on to the parts list and continually telling the individuals that this really is the part I want.
Old Nov 9, 2013 | 05:36 AM
CWBETB's Avatar
Pretty much. DOHC ZC is a jap spec engine so nobody would know the parts or the engine
Good luck!
Old Nov 9, 2013 | 07:12 AM
jlicrx's Avatar
if you are buying parts, an easy way to remember what you need is that everything below the top of the block is the same as the 88-91 Civic/CRX Si D16A6 - everything above the top of the block (including head gasket) is the same as the 88-89 (not 86-87) Integra D16A1 - the only exceptions to this are the timing belt itself which is the same as the 88 Prelude 2.0 Si (tensioner, water pump, etc. are same as D16A6), the camshaft timing belt gears which are DOHC ZC only (you can use B-series gears if you know how to install them as the timing marks are different) and the pistons which are DOHC ZC only
Old Nov 9, 2013 | 05:35 PM
swordofdoom's Avatar
timing belt has to BE DOHC 2.0 not the single cam 2.0 or your brains will explode when you match the new one with the old one.
FYI maintenance parts are pretty easy to get for this motor, you just need the right part number at the store.
Old Nov 10, 2013 | 03:31 AM
F22Who's Avatar
Thank you for the good info. I picked up some stuff and it was was easy just writing it down on a paper and just handing it to them. Appreciate the input.
WestSideRain
Jun 27, 2009 02:44 PM
MonsterRex
12
Dec 19, 2008 02:56 PM
LSVTECKING
Sep 10, 2003 10:13 AM
alky350
Jun 6, 2003 09:10 PM
91hatchnewb
May 12, 2003 10:55 PM
