Transmission & Drivetrain Gearboxes, Differentials, Clutches
rebuilt aoya
Old Nov 8, 2013 | 10:05 PM
armmata's Avatar
Default rebuilt aoya
i have a 1995 honda accord ex 2.2 with an auto transmission code aoya after the rebuild it will only shift in to gear for about the first 5 min after that it will not go into any gear.has anyone else had this happen or konw what could be going on with it.
Old Nov 21, 2013 | 07:32 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: rebuilt aoya
When you reinstalled the trans did you refill and prime the trans properly?
Start it up, let it idle and keep putting ATF into the trans. Check the dipstick after every quart. When the full mark is reached, place it into R, hold it for 10 seconds, then shift to N, hold for 10seconds, and down the line all the way to D1. Most likely at D4 it will either not engage or D4 will drop out and you will not be able to select any gear. Pull dipstick, wipe off, reinsert and check fluid, most likely it will be dry. Add a quart check again etc etc.
You will go through every gear and make sure every gear holds and then check the dipstick. Not until every gear holds and the case if full will the transmission work properly.
Old Dec 10, 2013 | 10:32 AM
armmata's Avatar
i did as your saying car ran fine for about 36 hours and now it will go down the road for about 3 or 4 miles then stops moving in any gear but if i turn the car off and wait about five mins restart it will move for about 3 or 4 miles then again no more movement
Shahab_Zia
Dec 9, 2018 10:41 PM
yingvang31
Apr 6, 2015 10:28 PM
cmasonman
10
Feb 21, 2012 11:01 AM
nivrat75
Apr 21, 2011 03:21 AM
xhondaaccord92x
Feb 12, 2009 09:30 AM
