Honda Accord '01 A/C part 2
Old Nov 7, 2013 | 02:04 PM
Ketchupmaker's Avatar
Default Honda Accord '01 A/C part 2
I'm back. I moved the heater valve on the heater hose in one direction or the other; this allows hot air or cooler air to enter the cabin depending on the position. This has been working out quite well.
New problem: There is now a repeated clicking noise that I can hear most notably under the dashboard towards the passenger side. It goes off if the heat is off. If the heat/air is turned to full blow, you can barely if at all hear the clicking, but I imagine this is because the air/heat is so loud when it is blowing full.
What is this clicking noise and how do I get rid of it?
Old Nov 10, 2013 | 03:05 AM
Lost Again's Avatar
Default Re: Honda Accord '01 A/C part 2
I'll guess the air mix motor is making the noise.....you'll have to get under there and narrow down what is making the noise.
Laithmeister
Feb 21, 2019 04:22 PM
Spades09
Aug 1, 2011 07:31 PM
is_07
Jan 27, 2005 08:39 PM
todnshay
Aug 8, 2004 05:53 PM
