t25 and t3/t4 exhaust flange question
is the 5 bolt exhaust flange for the t25 the same as the 5 bolt exhaust flange on the t3/t4 turbos? i have a t25 and was wondering if i wanted a t4 if i had to weld up a new exhaust flange or i can use the same downpipe.
thanks!
thanks!
No. they are not the same.
You have this.
It will not fit the 5 bolt FORD Style housing
If you have a T4, change manifolds entirely, as that goes to a completely different set of turbochargers in which your manifold would create too much back pressure to be effective.
You have this.
97Alex
Welding / Fabrication
17
Nov 29, 2011 01:13 PM
2muchPSI
Mar 5, 2006 11:33 AM
