97 accord downstream O2 sensor connector locatiin
Old Nov 7, 2013 | 07:04 AM
smitty5150's Avatar
Default 97 accord downstream O2 sensor connector locatiin
I hate to be the guy that asks the question that's been asked a million times, but searching has not helped and I want to dig in with some knowledge. I'm sure the plug is in the interior somewhere, but I would like to know exactly where. I'm getting a p0141(code 65) and I want to test the connection before crawling underneath. Thanks in advance.
Old Nov 7, 2013 | 07:38 AM
GhostAccord's Avatar
Default Re: 97 accord downstream O2 sensor connector locatiin
The downstream O2 is located post Catalyst under the vehicle. The direct wire connector is also under the car.
If you are looking for the heater circuit ground at the ECU it is Pin A5 (ORG/BLU or ORG/BLK wire) and the battery supply is the BLK/YEL wire from the under dash fuse box fuse no.4, pin 7.
Old Nov 7, 2013 | 09:21 AM
smitty5150's Avatar
Sweet, thanks. Made it almost 3 weeks without buying a manual, so that's good.
96dxcrapbox
11
Mar 3, 2012 01:00 PM
justdoinme23
Aug 25, 2010 04:37 PM
Creepshow S60
Aug 20, 2003 03:21 PM
Creepshow S60
Aug 20, 2003 10:15 AM
