Aeromotive FPR, push lock fitting for vacuum reference help......
So I know they make one, but I can not find the part #. Can anyone help me find a push lock fitting that fits the Aeromotive FPR vacuum reference port. As far as I know it is a 1/16" NPT thread in there.
I have searched and have either overlooked or can not find the part # for this fitting.
If someone has one they want to sell or can give me a part # I would greatly appreciate it. I am trying to avoid drilling and tapping my FPR to 1/8" NPT.
I just checked their website and it says its an 1/8" NPT port on that regulator… if that pic is from your setup what is the issue?
Also, why would I post up a pic of my own setup then ask for the part # to a part that I would not need? That pic is from another site (yellowbullet). No one ever listed a part # or where they got the part in the thread where I found that pic. But after some help from a member over on there I think I found the correct part # for the part I would like to use. This listing is from McMaster Carr.
Here is what I found:
So for future reference for anyone that would like to use a push lock fitting in the boost reference port on their Aeromotive FPR the 1/16"NPT to 1/4" hose fitting listed here should probably work.
I have a bunch of 1/16th, and 1/8 npt 90's and straights that take 1/4" line.. Pm me if interested.. I can put together a kit of whatever configuration you want with polyurethane line and fire retardant sleeving for high heat areas.
There you go man. At least I helped someone other than myself with this info. Check out the guy that posted in here, sounds like he has some better configurations and choices than what I listed.
Thanks man, and I will certainly keep you in mind, but I just ordered a couple from McMaster.
I am not a fitting expert, there are some guys on here that actually deal with this stuff, such as the guy that posted in this thread. Send him a pm.
The one that I got for the FPR is plastic. I have some brass fittings as well. In the past on a previous turbo setup I did not use the plastic near high heat areas.
Where did your fittings from?
fuckenboostin posted above us. He said he has a bunch of that stuff.
Most of my fittings came from my taking them home from an old job of mine and people giving them to me. These new fittings I got from McMaster, which is why I posted up the image of their site with the part #.
takes about 1 min to drill and tap it to 1/8" ..... I didn't bother looking as it would be hard to get, when I did mine... make sure you take the top half off before, if you do decide to make it 1/8"....
Yeah, I know I could have drilled and tapped it. I did not want to do that hence the reason for searching for this part.
So where did all you guys get the fitrings from online.. is the mcmasters site.. it the fittings plastic or what? Cant tell from the pics? Where is a good site to get the sleeves to go over it as well?
Just trying to see where all to get my stuff online.. thats all..
BeerBaron105
Apr 24, 2004 04:03 AM
Qwikrex
Jul 7, 2002 08:20 AM
