Want to Buy Want to Trade/Want to Buy
WTB: Innovative front cross member for EF8/9
Old Nov 6, 2013 | 02:42 PM
bird00420's Avatar
Default WTB: Innovative front cross member for EF8/9
Sup HT, Like I said....I'm lookin for the innovative front cross member for my 89 civic hatch. I don't want the competition setup tho, I'm looking for the one that utilizes the stock radius arms and bushings. Will need it SHIPPED to Bayfield, CO 81122. PM if you have one you want to get rid of.
Cheers
Old Nov 6, 2013 | 06:50 PM
EFnCRX's Avatar
Default Re: WTB: Innovative front cross member for EF8/9
I've got one and let me tell you it is complete ****.
Sits way to low and is made of some cheap chinese steal. Get anything but man.
You loose your factory jack point and this thing will colapse if you try jacking it up over time.
Old Nov 7, 2013 | 08:03 AM
bird00420's Avatar
Thanks for the reply EFn......do you have any pics of it on your ride that you could share to show me how low it sits? I'm not worried about a jack point.....the EF's have 4 of them right by the wheels for a reason LOL!!!
Old Nov 7, 2013 | 09:27 AM
EFnCRX's Avatar
Sorry the pic isnt better its 2 3/4" off the ground with my koni/gc
Old Nov 7, 2013 | 10:53 AM
mgs1098's Avatar
I had one when they first came out and took it off within 3 days. Its dangerous in my opinion. A real piece! If not wanting to use a traction bar, just modify your existing crossmember and put radius bearing in it.
Alan
Old Nov 7, 2013 | 12:45 PM
bird00420's Avatar
JESUS that's friggin ridiculous!!! I used to have a traction bar on mine but didn't like the feel of it since it was my daily driver......but it tucked up in the chassis just like the stock cross member.
Thanks for the pics EFn! And that is the actual Innovative mount and not just another manufacturer right?
Old Nov 7, 2013 | 03:03 PM
EFnCRX's Avatar
Correct innovative replacement crossmember, it hangs low and sucks but allows me to run a eg 1/2 size radiator without any lean and it feels solid on mine with the bushing kit. I plan on reworking it a bit when I get my welder, as alan said if you arent careful it can be dangerous hitting things with it.
Old Nov 8, 2013 | 08:16 AM
spcrxracer's Avatar
OEM is best.
Old Nov 8, 2013 | 09:09 AM
bird00420's Avatar
Yeah I can imagine! My f***ing header hangs low enough as it is.....I couldn't imagine having something hang that low!!! I wish someone would fabricate one of these that fit's in like the stock cross member I don't know why the stock replacement is so much different from the competition series.....when I had the competition series in my ride it fit just like the OEM???
Anyways, thanks for your replies......let me know if you end up taking it off and having it re-worked to resolve the clearance issue (pics would be great)!!!
Cheers
Old Nov 8, 2013 | 05:13 PM
EFnCRX's Avatar
Cheers
I for sure will, probably make it into a write up..
Whoever said OEM is best is wrong when it comes to the oem crossmember that thing is safe not practical for race cars lol
Old Nov 8, 2013 | 05:33 PM
thegatekeeper14's Avatar
I have one in my DA and its up and tight. I have zero complants and the style of the rods are better designed vs full race. who uses 2 rod ends where as Innovated uses one.
Old Nov 12, 2013 | 09:01 AM
bird00420's Avatar
up
Old Nov 12, 2013 | 10:05 AM
mgs1098's Avatar
Oem is best. Replace the bushings with bearings and it acts a traction bar and still sits up high. That innovative one is no good. You will hit curbs, steep driveways, and more. Its a good way to smack something and tweak the frame. But, to each his own, right.. II
Old Nov 12, 2013 | 10:57 AM
bird00420's Avatar
Thanks for the reply......I mainly just want it to shed pounds and gain more room under the hood. I'll probably just look into something custom made, or possibly find a used innovative one and modify that. I just want the flexibility/cushion of the bushings on the radius arms versus the solid connection for the 'full-race' versions.
1320DRAGWORKX
Aug 13, 2009 04:04 AM
sup gurl
Southeast (Sales)
Feb 1, 2008 11:19 PM
SILVER97EX
Jul 18, 2007 07:05 PM
