93 civic si clutch grinding
Old Nov 6, 2013 | 12:38 PM
soung87's Avatar
Default 93 civic si clutch grinding
Hey guys, I just recently put in a new clutch and release bearing. As I'm driving, I notice that my clutch is grinding everytime I shift gears. It only grinds when I release the clutch pedal. Can it be the release bearing or the clutch? Help..
Old Nov 6, 2013 | 02:10 PM
civiccoupe13's Avatar
Default Re: 93 civic si clutch grinding
I'm not a mechanic, but I guess it could be the thrust bearing in the gearbox?
Old Nov 6, 2013 | 02:13 PM
94EG8's Avatar
Seagull Management
Moved to the '92 - '00 Civic forum for better responses.
If it's grinding when you begin depressing the clutch pedal you've got a throwout bearing problem.
Old Nov 6, 2013 | 07:24 PM
Zeusfire69's Avatar
Sounds like you have a release problem...if the clutch does not completely release when the pedal is pressed, you will get grinding. The first thing I would try is bleeding the release system. If your pedal feels spongy, this is almost definitely your problem...
soung87
Transmission & Drivetrain
Nov 19, 2013 06:10 PM
b20integrapower
May 17, 2006 02:16 PM
siisgood00
Feb 18, 2005 07:29 PM
JdmFront619
Oct 28, 2003 12:25 PM
quik2kSi
Nov 12, 2002 12:01 AM
