Check Engine Light, 0 blinks?
Old Nov 6, 2013 | 11:53 AM
marcwinters's Avatar
Default Check Engine Light, 0 blinks?
A few days ago my CEL came on in my 88 civic hatch. Every time I reset the code via disconnect/reconnecting battery, the CEL comes back on immediately after I start it. After reading the sticky regarding CEL codes/diagnosis, I went under the passenger side dashboard and observed the ECU blinker.
The ECU blinker doesn't blink at all, and according to the chart, that means it's an ECU-related issue. Is there a possibility the blinker just doesn't work?
I tried to do some research on bad ECU symptoms: car won't start, reduced gas efficiency, etc. I don't have any of the symptoms that I read about.
If the code truly is zero blinks, and I do have an ECU problem, what's my next move?
Any help/feedback is greatly appreciated, thanks in advance!
Old Nov 6, 2013 | 12:02 PM
Freemananana's Avatar
Default Re: Check Engine Light, 0 blinks?
Possible. Try another ECU. What motor do you have?
Old Nov 6, 2013 | 12:19 PM
4drEF's Avatar
Keyboard Humorist
Are you putting a jumper in the service connector before looking at the light on the ECU?
Old Nov 6, 2013 | 05:26 PM
If I were to borrow another ECU, from what car would it have to be from? It's a d15b2
Jumper = paperclip/tiny wire?
service connector = harness under the driver/passenger side dashboard?
If so, I couldn't find one.
Old Nov 6, 2013 | 06:12 PM
Canadian_EF's Avatar
you've got an 88 so the small 2 pin connector is in the engine bay
you need a PM5 ecu to test. from any 88-91 civic/crx STD/CX/DX
Old Nov 6, 2013 | 06:24 PM
False alarm fellas, I'm an idiot. What I *thought* was the LED was the bottom part of a screw. Turns out the LED is flashing me 7 flashes which means faulty throttle angle sensor.
I appreciate all the help though! Sorry to have wasted your time!
Old Nov 7, 2013 | 02:31 AM
That's okay. At least you know what it is now. A faulty TPS would definitely cause your issue.
1sikhatch
Jan 31, 2010 09:06 AM
ls19integra95
Feb 26, 2008 07:16 PM
H22AEG2
Aug 10, 2005 02:56 PM
liquidxEG
Feb 22, 2005 03:46 PM
GeorgeY
Jun 29, 2003 08:59 AM
