Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
FN2 stage 1 upgrades, need advice
Old Nov 5, 2013 | 11:36 PM
djus's Avatar
Default FN2 stage 1 upgrades, need advice
Hey mates,
Already got all parts for my upgrade, here is a list:
1) TODA exhaust manifold
2) Invidia cat back
3) RCC intake manifold
4) HKS premium suction kit intake
5) Brian Crower stage 2 camshafts
6) Brian Crower Springs and Titanium Retainers
but have a real big doubt. My tuner says its ok, but another one doesn't even want to do a thing with my car after the mod. The biggest issue is installing Brian Crower camshafts stage 2 on my stock engine. I have no stroker kit and I'm afraid it can be lethal for the engine. What do you think on it? And also what do you think can be must have in addition to this mod?
Thanks
Old Nov 6, 2013 | 03:43 AM
Oxidious's Avatar
Default Re: FN2 stage 1 upgrades, need advice
Hi!
Quick question ( I have a FN2 also):
What is the overall cost for all that material?
Where do you live?
I'm doin a research as well.
Thank you!
Old Nov 6, 2013 | 05:12 AM
doood's Avatar
been there done that
there are no issues with running those cams on a stock bottom end, except you may be limited to how much vtc you can run. you would have to ask crower what they suggest as a safe max limit or clay the engine.
you'll of course need a tune after all this.
Old Nov 9, 2013 | 07:48 PM
civic20's Avatar
Those cams are a bit agrressive on a non stroked motor. But you did get valvetrain kits so it will not tear up anything. Question why did you go BC stage 2? Also found this from site Normally Aspirated Specification Hot street/strip or road race spec. Use with CAI, H, E, ECU, A/F mods. Excellent street manners and idle quality. Requires kit BC0040 or BC0040S. Did you get bigger injectors? crush the FPR?
Old Nov 9, 2013 | 08:12 PM
DaveSi677's Avatar
I would of gone with the drag cartel 2.2L instead they are way better... also if you need a tune I highly recommend VitViper he is one of the best!
http://vittuned.com/
Old Nov 10, 2013 | 06:45 PM
civic20's Avatar
Yes Vit is a great tuner! Drag cartel are nice but if you look on here or k20a.org they did a comparison on cams and for oem cams its k24a2 or a4 out of tsx that was better then the k20a.
Old Nov 13, 2013 | 01:40 AM
djus's Avatar
thanks, pal. got it
Old Nov 13, 2013 | 02:04 AM
djus's Avatar
mate, honestly I'm not very good in all this stuff and I went with BC because it was my tuner's advice. i did also check their page and I have no idea of what are CAI, H, E, A/F and your advice here will be very much appreciated. as for injections, they are standard as my tuner says stock ones are enough. what do you think?
Drag Cartel cams are much more expensive and again, I simply didn't know about them as for stroker, not in my budget now. if my mods are acceptable without it, I would prefer to think on it after brakes and rims exchange as now it is stock. heavy rims and very pour brakes..
thanks for useful info guys, but I'm from Russia and in my city there is only one guy who can handle Honda tunes properly (at least I hope so)) and at the moment I have k20
Old Dec 24, 2013 | 12:30 PM
97emsedan's Avatar
djus,
CAI is a Cold Air Intake, H is a header ( exhaust manifold), E is exhaust ( everything after the Header) A/F is Air/Fuel ( the tuning to get the engine to not run lean on an enlarged air intake system.
Hope this helps.
z6htch
10
Dec 24, 2012 01:22 PM
usdmblackcivic
18
Mar 25, 2007 02:39 PM
kornerk12
Feb 13, 2007 08:03 AM
da1lydr1ver
Honda Civic (2001 - 2005)
Feb 2, 2007 11:47 AM
thehondaguru
Sep 25, 2003 07:07 AM
