Taking apart tail light
Would taking apart the tail be the same as taking apart the headlights when you want to paint the housing ( Heating them up in the oven!) Is it also the same temperature? I need to reseal my tail lights because they have condesation and water is getting into them. THANX
yes, you can either use the oven to heat them or get a heat gun, both works well.
I have taken mine apart to drain them, just make sure that you seal them very well. I used aircraft silicone.
IDI2IEIAIVIS
Feb 23, 2003 08:46 PM
IDI2IEIAIVIS
Feb 22, 2003 06:27 PM
