Enkei j10 help
I came across this post on google, search.
I'd like to add that if one is considering getting these wheels (15"), that they will likely need new lug nuts as a 19mm socket will not fit.
The lug stud hole are a little over 22 mm, and 33mm deep (to the wheel hub). In regards to the 33mm, the nut will only reach (33 minus 5) 27mm deep.
Therefore you'll need a lug nut around 22mm x 50mm, with a thread of 12 x 1.5. Your local major auto parts stores will probably only have those 'key lock nuts' as the only ones that be fastened on. I came across 2 different 'acorn' designs on Amazon, that weren't 'lock nuts'.
Valve stem hole diameter is 11.3mm; 0.453" (11.5mm) is the closest size commonly available.
https://imgur.com/ABfOCLv
justBrowsing
May 1, 2012 06:29 PM
koto SM2
53
Mar 23, 2004 05:22 PM
so i need to replace it.. i have no clue if my wheels are 4x100/114.3 OR 4x100/108 Anyone know?
