ek hatch needs help - lights are out
I need some advise here
just put aftermarket steering wheel and cluster and a/c, heat panel light went out.
checked fuse, ok.
What else I need to check??
radio is working
checked fuse, ok.
radio is working
Well the first thing i would do is check the dimmer switch to see if it is turned down or if it went bad or if it's disconnected. if that checks out fine then i would test the fuses again with a fuse tester or multimeter as a blown fuse can still look good to the naked eye.
Mitch965
17
Feb 6, 2013 12:17 PM
stupidasso15
16
Mar 15, 2012 09:07 PM
barone
Jun 4, 2011 07:21 AM
sgtroseberry
Sep 6, 2006 12:38 PM
