Spoon wire still good??
It has a little cut and it shocks me when I touch it.. I electric tape it and now it doesn't shock me anymore..can I still use it? Or is it bad now?
Also I bought g power ngk, will these be okay? The one I took off were ngk R plugs, but it's expensive and I'm on a budget.
Thanks
Thanks
if you have new plug wire just use them and sell those one's to some kid that drools over spoon/mugen lol. but if it's not causing a mis or anything you can leave them too.
Edit: just googled them 270$+ used ? lmao I'd go with the "coil on plug" retrofit from Hondata and gain something they do look cool tho.
If you got a shock off it when it was still plugged in, you have a problem, replace them.
You should not get a shock of spark plug leads, [any brand] when they are still plugged in.
You can use a multimeter to test the resistance of the leads, they should all be about the same, if there is a big diff. on any one of them, it will affect performance, although the spark plugs all look OK. 94 94
