hardrace lca
Old Nov 4, 2013 | 03:37 AM
jdmem205's Avatar
Default hardrace lca
Has anyone ran these rear lcas and had any review on them? I know I could just get there bushing kit to place in my stock arms but I rather change the arm and make look pretty while upgrafing bushings.
Thanks for any info guys.
Old Nov 7, 2013 | 08:37 PM
jdmem205's Avatar
Default Re: hardrace lca
Nobody?
Old Nov 7, 2013 | 08:41 PM
TypeRfit's Avatar
RESIDENT
Save the money and buy their master kit. I did the master kit in my Db and love it, tightened up the entire car very nicely.
Old Nov 7, 2013 | 08:55 PM
Deetz's Avatar
Crazy Honda Guy
I went the route of Prothane trailing arm bushings, thought it was a better option
Old Nov 8, 2013 | 06:54 AM
94CivicSi's Avatar
+1 on the Prothane bushings in stock LCA's. Mine have a 100K on them now.
Old Nov 11, 2013 | 04:59 AM
jdmem205's Avatar
Wow really I've heard good things about prothane. But vi also heard you have to replace them every 2 years or so. I don't plan on tracking the car. The only reason I'm not aiming for replacing bushings on stock parts is I don't want to go thru the process of pressing bushings out etc.
Old Nov 11, 2013 | 05:11 AM
purgat0ry's Avatar
I'm running the entire kit (save for UCA's, I ran out of time and steam on suspension at the time) on my EM1, I did notice a big difference over the OEM bushings, then again, the OEM bushings were in terrible shape.
Old Nov 12, 2013 | 08:57 AM
94CivicSi's Avatar
I wanted to stick with stock arms for my daily. The roads are here are pure hell and I didn't think aluminum arms were up to the duty cycle.
You can either cut or burn the rubber out of the stock bushing, use a hack saw to put a small cut in the "shell" that's left behind in the control arm, then just knock it out. I did put the ES master kit in my previous car and used that method all the way around.
Old Nov 12, 2013 | 02:35 PM
Deetz's Avatar
Crazy Honda Guy
The above poster has 100k on his, i doubt that was in two years. OP, i don't think you should listen to hearsay, and start listening to the real world which in this case gives a thumbs up for them!
moco_machine
10
Aug 19, 2008 09:36 AM
FakeJDMEF8
Sep 9, 2006 07:52 PM
TeaAddict
Dec 7, 2004 06:29 PM
sircrxracer
12
Mar 17, 2004 09:05 AM
SPiFF
49
Mar 26, 2003 04:26 AM
