UPGR8 fuel regulator? Any info!!
I was looking online to bought a AEM FPR and see this UPGR8 with practical the same design. And want to hear if somebody have use it, if is a Chinese crap or is worth to buy it.
Or any advise what regulator to use that be fuel rail direct fit.
Not B&M please.
Not B&M please.
I'm running stock base pressure with 1000cc injectors.
Look into bdl regulators too. I picked up mine for a hundred bucks from laskey. Also matched it with his fuel rail.
.. I see alot of people use factory fuel rail and fpr and larger injectors and are able to make 500 hp with no problem. Is it safe to say that you are not required an upgrade to rail and fpr if your not going over 550 to 600 hp?
You need to know how much fuel you need based on the type of fuel you are running.
You need to know how large injectors you need based on the power you are aiming for.
You need to know how much fuel flow you need based on the power you are going for.
So if you need a higher base pressure to allow your injectors to flow x amount of fuel you need a regulator.
tooquik209
Sep 11, 2012 12:40 AM
