1993 accord lx brake pedal travels to floor after brake job
Old Nov 2, 2013 | 03:40 PM
scubacamper's Avatar
Default 1993 accord lx brake pedal travels to floor after brake job
I replaced the front rotors, pads, driver's side axle, and replaced the brake fluid by bleeding at all 4 points.
Now to my surprise, the pedal travels to the floor (!). After doing some reading online, I decided to replace the master cylinder.
Now, after a new master cylinder, the pedal STILL travels to the floor. What is going on here?!
(firm then spongy with car off, travels to the floor with car running).
Please help!!
Old Nov 2, 2013 | 06:17 PM
campfire's Avatar
Default Re: 1993 accord lx brake pedal travels to floor after brake job
you have a bubble somewhere still. i had the same problem before i also changed the master cylinder still had bad pedal.. i found my air bubble in the rear.. i had to bleed like a half a quart to finally get it out.
Old Nov 3, 2013 | 09:43 AM
You were right campfire - to eliminate the possibility, I went around again and bled all the brakes - all is fine now.
laurentj23
Jan 28, 2012 06:55 AM
LOVEthatDC2
Sep 15, 2009 06:16 PM
sobey
Mar 11, 2009 06:08 PM
JZA70
Nov 14, 2006 11:16 AM
1lowsol2
Sep 1, 2006 03:12 PM
