best header for B18c
i have fully stock dc2r with b18c
i have 4-2-1 plm toda replica header and please i would like to know maybe some another header will be better!!
at PLM i make on the dyno run 200.7 hp on flywheel
also car have password jdm intake!
ecu stock
100-000km range of motor
thank you
ecu stock
thank you
lol why do ppl hate that intake so much ? I love mine.
What are your future plans ? that header is pretty good overall vs most out there, the plm bigtube is maybe something to consider depending what you've got planned.
and maybe some cams
what s the difference big tube from mine?
You wont see much gain until you can tune your ecu. That header you have is great, dont get rid of it. That intake sucks, and not in a good way. Look it up if you dont believe me.
Those intakes look cool, but that's about it. For an intake setup you want a 3" cold air intake with a velocity stack tuned for length on your motor.
I am running the PLM Toda rep also on my car, I would not change it.
Since you refused to look into why its a bad choice yourself. I found a thread that was dyno tested vs a CAI
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/dyno-results-js-racing-intake-vs-aem-cai-my-itr-js-intake-racing-all-hype-1194241/
If this car is not going for performance in mind then by all means, get the chambered PWJDM intake.
The Air coming into the intake is slowed down going from small, to big, back to small...
There is no velocity, you'll make more power with no intake then you will with that piece of **** intake.
Put a nice, 3'' intake on there, or a tuned length and i'd think this could make another 5-8whp then what u have now.
Its ok - All you can do is suggest, and help. Sometimes people will listen, sometimes they wont. Its the one's who aren't active on the board, and that are scared to ask questions. This helps.
Jump on ebay there are alot of good choices on there
http://www.ebay.com.au/itm/161005607...84.m1423.l2649
http://www.ebay.com.au/itm/Blox-Velo...fc68556&_uhb=1
