can you remove the plastic back piece from the headlight ?
(my car is 90crx, ),
i was wondering if you can seperate the plastic back side piece of the headlight, so it comes off the glass headlight part ? or is that part of the whole main headlight assembly ? where its permenantly attached to each other ?
my driver side headlight has a broken piece that goes on the back plastic part which is where one of the adjusting oval things screws into, so without it, its all loose and wobbly.
so i wanted to see if i could just get some cheap priced used crappy headlight and just use the back plastic part, and put it onto my headlight, which is in good condition.
i did'nt think of that, at least there is a way to seperate and take that part off, well if i do that i'll be sure to just use a lower bake setting to be safe and see how it works, and if needed i can always do again with higher temp.
do you know if the headlight assembly from any other EF civic models fit the crx and use the same headlight ? thanx
i also have a heat gun, so i can maybe try using that also, to heat it, softening it to seperate that piece ?
crXtreme_girl
Sep 17, 2002 04:23 PM
