91 Civic Hatchback Si - i wanna do street and track
Old Nov 2, 2013 | 09:29 AM
lil91honda's Avatar
Default 91 Civic Hatchback Si - i wanna do street and track
any one have any ideas what i should do to my honda i wanna do street and track thats the idea so far but have no idea were to start.
Old Nov 2, 2013 | 09:47 AM
Freemananana's Avatar
Default Re: 1991 Honda Civic Hatchback Si
What's your budget?
Old Nov 2, 2013 | 10:01 AM
F22Master's Avatar
So you want a car that does everything, but you know nothing. And let me guess, you want to spend as little as possible?
Old Nov 2, 2013 | 10:04 AM
Haha, don't we all?
If you want something that is streetable and good on the track, as in circle track, just upgrade the suspension and make sure it runs. Then have fun with it.
Old Nov 2, 2013 | 10:57 AM
instrument's Avatar
sis do pretty good in stock class, if thats the track youre referring to.
Old Nov 2, 2013 | 12:08 PM
.Manny.'s Avatar
Touching My Member
Start with replacing all the old and worn suspension, steering, and brake parts. You'll thank yourself down the road.
Old Nov 2, 2013 | 01:08 PM
Not sure about the specs on the SI, but I did a DA brake conversion on my car so it has disc brakes and they are larger than stock in my case.
Old Nov 2, 2013 | 01:10 PM
.Manny.'s Avatar
Touching My Member
DA or EX knuckles are a nice upgrade. 10.3" I think to the stock 9.5"
Old Nov 2, 2013 | 01:32 PM
DA>EX due to price and availability I would say.
Old Nov 2, 2013 | 02:01 PM
.Manny.'s Avatar
Touching My Member
True Story. I just left the stock front knuckles and slapped a set of Wilwoods on there.
Old Nov 2, 2013 | 08:42 PM
lil91honda's Avatar
funds are no problem for me i had a civic awhile back ago and cam across the si i got from an ex coupe i just started taking it apart today but was thinking of doing a mini me go from a D16a6 to a D16y8 what you guys think
Old Nov 2, 2013 | 08:43 PM
lil91honda's Avatar
i will post pics of my project
Old Nov 2, 2013 | 09:34 PM
lil91honda's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
this is wat was done today
Old Nov 3, 2013 | 10:26 AM
If funds are no problem, go all out! Don't do a mini-me if you can afford more. GSR, K20A, J32 or something along those lines.
Old Nov 3, 2013 | 05:34 PM
lil91honda's Avatar
Default Re: 91 Civic Hatchback Si - i wanna do street and track
CAN YUO GIVE ME SOME MORE INFO ON THE GSR AND K20A OR J32 I WOULD BE HAPPY WITH THE INFO ON T THAT MAN .
Old Nov 4, 2013 | 03:04 AM
Here's a good one.
http://www.ef-honda.com/ben/EFswapguide.html
JDM B18C Type R[edit]
VTEC
Found in: 96-01 JDM Honda Integra Type R DC2 Rev-limit: 8600 rpm
Power: 200 PS (147 kW; 197 hp) @ 8000 rpm & 133 lb-ft @ 7500 rpm
Transmission: S80 with Helical LSD
S80 spec: J4D (96 Spec: 4.4 final drive), N3E (98 Spec: 4.785 final drive w/ 1.034 4th & .787 5th Gears)
Displacement: 1,797 cc (109.7 cu in)
Compression: 11.1:1
Bore: 81 mm (3.2 in)
Stroke: 87.2 mm (3.4 in)
Rod Length: 137.9 mm (5.4 in)
Rod/Stroke Ratio: 1.58
VTEC Engagement @ 5600 rpm (98specR)
ECU code: P73-003 (96specR) P73-013 (98specR)
K20A[edit]
Found In 2007+ JDM Honda Civic Type-R (FD2) Displacement: 1,998 cc (2.0 L; 121.9 cu in)
Bore x Stroke: 86 mm (3.4 in) x 86 mm (3.4 in)
Compression: 11.7:1
Power: 225 PS (165 kW; 222 hp) @ 8000 rpm
Torque: 215 N·m (159 lb·ft) @ 6100 rpm
Redline: 8600 RPM
i-VTEC Engagement: 5800 RPM
2002-2008 JDM Honda Accord Euro-R (CL7) Displacement: 1,998 cc (2.0 L; 121.9 cu in)
Compression: 11.5:1
Power: 220 PS (160 kW; 220 hp) @ 8000 rpm
Torque: 206 N·m (152 lb·ft) @ 6000 rpm
Redline: 8600 RPM
i-VTEC Engagement: 6200 RPM
2001-2006 JDM Honda Integra Type-R (DC5) Displacement: 1,998 cc (2.0 L; 121.9 cu in)
Compression: 11.5:1
Torque: 196 N·m (145 lb·ft) @ 7000 rpm
Redline: 8600 RPM
i-VTEC Engagement: 6000 RPM
2001-2005 JDM Honda Civic Type-R (EP3) Displacement: 1,998 cc (2.0 L; 121.9 cu in)
Compression: 11.5:1
Power: 215 PS (158 kW; 212 hp) @ 8000 rpm
Torque: 200 N·m (150 lb·ft) @ 7000 rpm
Redline: 8600 RPM
J37A1
2007-2013 Acura MDX
Displacement: 3,664 cc (223.6 cu in)
Bore and stroke: 90.0 mm (3.5 in) x 96.0 mm (3.8 in)
Compression: 11.0:1
Power; torque: 300 hp (220 kW) @ 6000 rpm; 275 lb·ft (373 N·m) @ 5000 rpm
Valvetrain: 24v SOHC VTEC
Fuel control: Multi-point fuel injection; PGM-FI
J37A2
2009-2012 Acura RL
Compression: 11.2:1
Power; torque: 300 hp (220 kW) @ 6300 rpm; 271 lb·ft (367 N·m) @ 5000 rpm
Valvetrain: 24v SOHC VTEC (intake and exhaust)
J37A4
2009+ Acura TL SH-AWD
Compression: 11.2:1
Power; torque: 305 hp (227 kW) @ 6300 rpm; 273 lb·ft (370 N·m) @ 5000 rpm
J37A5
2010-2013 Acura ZDX
Compression: 11.2:1[4]
Power; torque: 300 hp (220 kW) @ 6300 rpm; 270 lb·ft (370 N·m) @ 4500 rpm
Old Nov 4, 2013 | 03:33 AM
sh1ntaox's Avatar
10 Year Member
keep it stock. keep the a6.
Old Nov 4, 2013 | 03:58 AM
Fliptard's Avatar
do not replace an a6 with a y8, that's downgrading the bottom end. At least put the y8 head on the a6 block.
Old Nov 4, 2013 | 05:20 AM
92HatchHybrid's Avatar
Oh boy. Save yourself the headache and find some car guys that will help you and know what they are doing.
Old Nov 4, 2013 | 06:04 AM
Dark_Teg's Avatar
Mini-me - Is a waste of time and effort. I don't know what track you are referring to but a mini-me wont outrun much.
Old Nov 4, 2013 | 06:12 AM
JuggerNaut-CTR's Avatar
You want to track the car...and funds aren't a problem...yet you want to replace a low power single cam for another? Unless you have plans of building/boosting the single jingle, it will be a huge waste of time.
Old Nov 4, 2013 | 08:05 AM
Not a bad idea. The A6 isn't very impressive, but it's a fine motor for what he wants to do. Keep it stock and stay in that class.
Yup, that's pretty agreeable. The Z6 would be an upgrade because of the VTEC head, but the block is the same as the A6. So the A6-mini me would be the best bet for money.
Not really sure what this means. I used the internet as my 'car guy' and got along quite fine. I was completely clueless a couple years ago. Since then I've rebuilt a couple motors, changed a few clutches, and overall just gained some valuable experience.
Old Nov 4, 2013 | 08:07 AM
Aw, by that logic aren't all the SOHC VTEC motors a waste of time and effort? I like the mini-me if that's as far as the budget can go.
This is my thought process too. If funds aren't an issue, there is no reason to go anything short of a mid-engine twin turbo J37A. Right? I wouldn't build and boost a single cam personally. I think if you are going to build a motor, you might as well start with something a little bit bigger and better. Unless he is trying to be the best SOHC around or brag about having a built SOHC, the DOHC is a better option.
Old Nov 4, 2013 | 08:16 AM
4drEF's Avatar
Keyboard Humorist
Here is the questions you MUST answer.
street as in street legal?
Track - what kind of track? I'm assuming quarter mile because you asked for info on the J motor. That's not going to be very street friendly at all. Good luck finding a hood.
What are your POWER goals?
Old Nov 4, 2013 | 08:26 AM
Street legal depends on where you are located too.
Track is probably 1/4 mile since that's what HondaTech seems to be focussed on. The J-series can fit under the hood on an EG, not sure on the EF. Depends on your mounts I guess and your ride height for the oil pan. There is also the option of a hood scoop like the 5.0 Mustangs had back in the day. The big backwards scoop, whatever you call em, to clear the carb or supercharger.
Lastly, power goals are important. I read this thing once about power in the Honda world. A 600 HP GTR is fast on the street. A 600 HP integra is just scary on the street. You have to take it into perspective. You can drive it, but it may not be reliable, safe, or comfortable depending on what you do to it.
Just a little bit about how streetable some cars are. My civic has a ACT clutch, forget which one. But anyways, it's a 'racing' clutch. It's pretty hard to press down compared to stock. My girlfriend actually can't press it down, not saying much but just remember that. If she needed to drive me somewhere and my car was the only car, we wouldn't be getting anywhere. The gap between engaged and disengage is VERY narrow on my pedal. It makes it hard to let the clutch grab on a hill. So if I'm at a light, I have to press on the brake to stay put. Then if we start moving there is no slowly let off the clutch till you feel it grab, let go of the brake and drive. It's drop the brake, hit the gas, roll backwards, spin the wheels and go forward. Just little things to keep in mind. Also, if you go to pep boys to get your oil changed and you tell them it's an 89 civic and they will fill it with D15 levels of oil, even if it's a V6 J32 in there. And when you tell them it's a 94 Del Sol VTEC because you swapped a B16 in there, they will look at you like an idiot when they see your little EF civic. And don't give me crap about getting my oil done somewhere, I was in a rush and I dropped the car off!
End rant.
