Hesitation on a 95 accord :(
Old Nov 1, 2013 | 10:30 AM
bcintron95's Avatar
Default Hesitation on a 95 accord :(
Whenever im cursing in traffic (around 1-2 rpm) ill break and the try to accelerate. Ill get some hesitation untill i floor it and then it just shoots out and acts normal. Whats up with my car? Would this be a fuel filter problem or should i get my air intake manifold cleaned out? All of my wires and fluids are good and have boesh spark plugs in.
122k miles
4cyl
auto
Old Nov 1, 2013 | 11:06 PM
holmesnmanny's Avatar
Default Re: Hesitation on a 95 accord :(
sounds like oxygen sensor is bad...buy a Denso oxygen sensor and drop it in
Old Nov 2, 2013 | 02:50 AM
L2ILL's Avatar
It could be a number of things...check your ignition system first...if you have good spark...then check your idle speed and idle components...you could also have a slipping tranny imo usually does what you described. If u havent serviced its oils I would suggest u start now...but it may already be too late. No exageration slippage if it is like that is going to get worst....fast. change oil asap.
JoeyJdm813
Mar 19, 2015 09:02 PM
Ntense_Civic
Apr 20, 2012 04:47 PM
integra_661
Dec 8, 2011 12:56 AM
Canonm7
Jul 22, 2003 12:24 PM
