anyone know where i can buy these parts ? (shown in diagram)
i was looking for a place online that sells the plastic parts for the headlight bracket that the adjusting screw goes through, (#7, #8 & #25 in diagram),
cause mines broken on drivers side & headlight wobbles around & is'nt aimed properly,
plus its crooked looking & not lined up with the corner light.
it was'nt even listed on majestic honda when i checked so maybe discontinued ? from them only? or just discontinued everywhere?
just seeing if anyone knows where i can order some that still carries them ? otherwise i will try to find some at junkyard if nobody took them off the cars already
Last edited by crxaddikt; Nov 1, 2013 at 10:09 AM. Reason: the code i put to show the image was wrong
you can get number 8 from bkhondaparts
http://www.bkhondaparts.com/parts-ca...fuel/headlight
if you google the part numbers for the other 2 you can probably find them on ebay or somewhere like that
alright thanks, yeah i'll give that a try and put the part numbers in google, and i'll check that link you gave me out, and guess call dealer also, cause maybe its not discontinued ? i can't assume just cause majestic honda's site shows discontinued that nobody else has them
If they list it discontinued, it is. Your dealer might get lucky and locate them in a warehouse or on another dealer's shelf. Otherwise, used is the only way.
after looking at the back of my headlight assembly a little better, i noticed the part thats broken is on the plastic piece on backside of headlight, on the bottom outter corner, theres an oval recessed area that part #7 fits into, and on mine its broken on the bottom of it so it won't hold part #7 properly,
so really i need to buy a headlight assembly, unless i can glue it in place or screw it so it stays in place ??, but its probably better do it the right way so it can be positioned and adjusted correctly.
JoyBoy, i might still need those parts mentioned above in the post, i just need to make sure, but if i need them i'll PM you about it, thanks for telling me
grant_abby
Honda Civic (2001 - 2005)
Jan 4, 2016 09:20 AM
slipyoke
37
Jun 8, 2015 08:16 AM
kchungb17a
Jan 29, 2012 01:09 AM
