Weird clutch issue
Old Oct 31, 2013 | 06:38 PM
Vash121991's Avatar
Default Weird clutch issue
I recently replaced the y7 motor in my crx with a sohc zc
I used the flywheel clutch disc and pressure plate from my crx along with the 91 si tranz
Everything worked when it was on the y7
But on the zc my car doesn't die when u put it in any gear and let of the clutch and gas. It just stays running.
I can shift threw all gears fine with no grinds or anything.
If I start the car in first it doesn't jerk or anything.
Any help?
Thanks!
Old Oct 31, 2013 | 11:43 PM
Vash121991's Avatar
Default Re: Weird clutch issue
Please help
Old Oct 31, 2013 | 11:51 PM
DCRB's Avatar
is your clutch cable adjusted too tight?
Old Nov 1, 2013 | 02:38 AM
Freemananana's Avatar
Possible. Is that flywheel compatible with the ZC? Clutch is tranny, flywheel is motor, right? You do have axles right?
Old Nov 1, 2013 | 09:08 AM
Vash121991's Avatar
The cable adjustment makes no difference. I can adjust it tight as a I want. And I can even loosen it and take the cable all the way off. No difference car still runs in gear.
I took the y7 flywheel and put it on the zc so I'm wondering if they are compatible or not. And the axles were from my last motor. But I don't think an axle would make my car run in gear either.
Old Nov 1, 2013 | 09:34 AM
4drEF's Avatar
Keyboard Humorist
Since you used the same trans, flywheel, and clutch from your last motor, then you obviously have the correct parts.
You would have to have left out the clutch disc, severely broke the disc, broke all the springs off the plate in order to not even get a noise from the clutch when you run the engine.
If the clutch fork is STUCK pressing down on the clutch plate, then you could be staying disengaged.
If the transmission catastrophically broke internally then your axles won't spin.
If your axles are not engaged into the differential or the wheel hubs then the won't spin.
What would I do? I would put the front end up on jack stands. In neutral, you should be able to spin either wheel and the other wheel will then spin the opposite direction (unless you have an LSD whereas it would then spin the same direction).
If the opposite wheel doesn't spin then inspect the axles and make sure they aren't snapped. Make sure they spin when you spin the wheels. Remove the axles and take look into the holes. When you turn the engine over in gear, the diff gears should turn.
If not, then the tranny has to come off any way you look at it.
Old Nov 1, 2013 | 11:22 AM
Vash121991's Avatar
The wheels don't spin. And I think it's flywheel related does anyone know if the y7 flywheel sticks out further?
Old Nov 1, 2013 | 12:10 PM
ej1995's Avatar
Shouldn't be a flywheel causing the issue. Does it feel normal when you press in the clutch and release it?
It sounds to me like you have an axle thats not all the way in or something to that nature.
Old Nov 1, 2013 | 01:00 PM
Vash121991's Avatar
Clutch feels good. And why would an axle make my car run in gear
Old Nov 1, 2013 | 01:24 PM
4drEF's Avatar
Keyboard Humorist
Jacked up and the wheels do not spin when you turn them with your HAND?
Old Nov 1, 2013 | 02:00 PM
Vash121991's Avatar
Oh. Then they do the axles also spin when I spin the motor with the crankpully bolt. But when I'm up in the area and the car is in first and I give it gas they don't spin. And when I don't give it gas the car doesn't die. It just stays running in any gear
Old Nov 1, 2013 | 02:05 PM
4drEF's Avatar
Keyboard Humorist
"he axles also spin when I spin the motor with the crankpully bolt"
but (still with the front up in the air) the wheels do NOT spin when the engine is running?
That's really not possible.
The only difference there is that you are turning the crank with your hand in one scenario and the other scenario the crank it turning under power of the motor. either way the crank is turning.
Old Nov 3, 2013 | 03:22 PM
Vash121991's Avatar
they only spin a very little with the motor on. And my car still stays runnin with the car in gear
murderex
Apr 3, 2008 06:21 PM
justseeingifitistaken
Feb 10, 2007 03:03 PM
primecrex
Jan 24, 2005 10:53 AM
90CRX
Aug 18, 2003 04:08 PM
Ronin Panda
15
May 11, 2003 05:05 PM
