Ecu question
Old Oct 30, 2013 | 05:10 PM
Pat_Black's Avatar
Icon2 Ecu question
So I recently dropped a 00 b16a2 into my 98 cx hatch. I'm running the stock cx harness and ran all the necessary wires for vtec, knock etc. I have the 00 si ecu that came with the engine. Obviously I can run a jumper harness to the ecu for obd2a to obd2b, but I'm not sure if I will pass inspection with that. Is there a ecu that I can run without a jumper harness that will allow me to pass NYS inspection?
Old Oct 30, 2013 | 06:54 PM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default Re: Ecu question
Obd2a p30 from a Del Sol. A p2t will not pass unless you get the ftp sensor, or your state allows monitors to not be ready.
Old Oct 30, 2013 | 06:57 PM
Pat_Black's Avatar
That's the only one huh? They seem impossible to find.
Old Oct 30, 2013 | 08:16 PM
Em1-2race's Avatar
What state do u live? I live in cali nd to pass the inspection I had to use everything the engine had as cat to evap sensor to the harness nd ecu with out mods so ur using a obd2b engine
Old Oct 31, 2013 | 03:13 AM
doctorake's Avatar
Community Builder
Check to see if you can have monitors offline, if they let you have one offline you can use the the p2t, or get the ftp sensor
Old Oct 31, 2013 | 04:33 AM
Pat_Black's Avatar
I live in NY. I'm have an obd2b engine and ecu. They allow up to two. Monitors to not be set.
Old Oct 31, 2013 | 05:34 AM
doctorake's Avatar
Community Builder
You might be ok with the P2T then as long as you do this.
http://technet.ff-squad.com/code91.htm
Fool the ecu
We fool the ECU by providing a similar voltage that the FTP would normally send -- this happens to be around 2.5v. You need to acquire a 10k linear potentiometer: Radio Shack Part Number 271-1715.
The outter 2 pins are going to be +5v reference and ground (does not matter which), while the center pin will be your output feeding back to the ECU pinout.
(Before you hook up the pot's center pin to the ECU, use a multimeter to adjust the output to 2.5v.)
Here are the 96-98 civic & integra ECU pin assignments:
D10: +5v
D15: FTP input
D11: GroundHere are the 99-00 civic & 99-01 integra ECU pin assignments:
C28: +5v
A29: FTP input
C18: Ground
When I ran that I think I only had the one monitor not online due to it not being a complete trick to the ECU. It gets rid of the CEL but the emissions monitor is smarter and sends variances in the voltage and since it will not see the variances it will never come online.
Old Oct 31, 2013 | 06:06 AM
Pat_Black's Avatar
Cool. Now I have a few options. I'm hoping I can find a obd2a p30 for sale. Thanks
Old Oct 31, 2013 | 06:26 AM
doctorake's Avatar
Community Builder
They are rare, I ended up finding mine on eBay and paid $300, I would go with the P2T.
Old Oct 31, 2013 | 06:49 AM
Pat_Black's Avatar
Wow. I just want my inspection to be a easy as possible. Eventually I wanna run a standalone.
Old Oct 31, 2013 | 12:35 PM
Pat_Black's Avatar
Would I be able to use a 96-98 itr ecu?
Old Oct 31, 2013 | 12:55 PM
doctorake's Avatar
Community Builder
I don't know, but those are pretty rare also. A JDM ECU will not pass emissions at all also.
Old Oct 31, 2013 | 01:00 PM
Pat_Black's Avatar
All I can find are obd1 p30s. I see more itr ones. Idk if it matter that it's a b16 and not a b18. I didn't think a jdm one would.
Old Oct 31, 2013 | 01:21 PM
estewar03's Avatar
Damn Im glad I have a local hook up where I live and dont have to worry about the visual inspection crap. Just go for the jumper harness and be done with it.
Old Oct 31, 2013 | 01:56 PM
doctorake's Avatar
Community Builder
P2t is an easy option with minimal wiring.
Old Oct 31, 2013 | 01:57 PM
Pat_Black's Avatar
It's actually not a visual inspection. My car has to be plugged into a machine and has to come back with no codes. I think that is my best bet.
B(eighteen)C
Engine Management and Tuning
Nov 30, 2012 01:14 AM
ekx4
Oct 2, 2005 11:52 PM
ZappasOne
Oct 15, 2003 07:00 AM
