f23 harmonic balancer trouble
Old Oct 30, 2013 | 05:08 PM
JessTheWarBear's Avatar
Default f23 harmonic balancer trouble
So I am trying to remove the harmonic balancer from my f23a block its going in my 2002 accord ex and I have the Honda balancer holder tool and I cannot get the center bolt to move at all am using breaker bars and no luck. I might also add that the motor is not in vehicle and no transmission is connected to it not sure if that makes any difference. Its just kicking my butt and I am unsure when I look it up it looks like it should not be this difficult. I broke a breaker bar. Any help or pointers would be awesome thanks.
Old Oct 30, 2013 | 11:04 PM
holmesnmanny's Avatar
Default Re: f23 harmonic balancer trouble
If it hasn't been off in a long time it will be hard. Take out the spark plugs. Use a half inch ratchet. Use a cheater metal pipe over the ratchet. Or better yet find someone with a very powerful impact gun or battery impact gun. I assume you're using a 19mm metric socket. It's best to actually have a jack directly underneath the socket so that you can jump/bounce on the cheater pipe lol You want the socket as straight as possible for maximum leverage.
just throwing ideas out there
Old Nov 2, 2013 | 09:57 AM
Lost Again's Avatar
But "holmes" the engine it not in the car.
OP - two large friends with the breaker bars and "pipe" - have the "bars" set at about 45 to each other and them have the large guys push at each other - in the proper direction of course.
I say large guys as I'm 145 wet with clothes on....so I have to buy expensive air tools and/or long pipes to get "things" to happen.
Heat (propane) might help.....I'd replace the crank seal if you go that way. Cold might help as well - CRC freeze off?
Old Nov 2, 2013 | 03:00 PM
If the engine isn't in the car then odds are it's on a stand. Still makes no difference in what I said engine in or engine out.
Old Nov 6, 2013 | 08:53 PM
Thanks Guys I used a cheater bar and had my brother help. I punched myself in the face when it broke free but thanks for the ideas lol.
Msciume53
Jan 10, 2015 08:07 PM
1991ED6
Mar 2, 2013 07:52 PM
beutler09
Mar 31, 2009 01:37 PM
scharles
Nov 27, 2002 11:40 AM
djtony5
Nov 13, 2002 02:05 PM
